Sounds like the belt needs replace. You can order parts threw Sears or probably Lowes. Its a relatively simple job. 30-60 minute job. Sears carries appliance parts of all sorts. You'll be amazed at what you can find at Sears. You'll have to ask in appliances. But they do carry appliance parts . Remove housing cover and get a better look at the inside. You'll see that it's probably your belt has popped or your motor is gone out. If it's your motor, your probably in for a long job. Either way, there is many stores that carry appliance parts. Just take the modal number down and the make of the washer, and you can pretty much go by that.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
