Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
Gerard Cannoo Posted on Apr 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi My dishwasher seems to get stuck in a cycle when you start it - it lets water in for around 20 secs - then pumps it out - then lets water in for say 20 secs then pumps it out - over and over and over... Model - says electronic on the front, has a rotary selector switch and a power switch on the panel along with three indicator lights. SGS43EO2ZA/16 Type S1501B Can you advise? Gerard
DILLIGAF
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Apr 24, 2011
DILLIGAF
Master
Level 3:
President:
Answers
1140
Questions
Helped
680934
Points
4145
Hello Gerard,
This is an overfill 'fault' generally caused by one of the following:
1. Faulty or incorrectly installed flow-meter
2. An airlock in the fill chamber
3. Faulty float switch (less likely)
There are some simple checks you can do to determine the cause of the fault and hopefully solve the problem without replacing any parts - no tools required at this point.
First, open the door, pull out the lower basket and locate the float. This is the 'mushroom' in the base of the washing compartment:
Hi
With the washer empty of water, make sure the float is fully lowered. There should be a gap of 2-3mm between the float and the base of the washer and you should be able to lift it about half an inch / 12-15mm. When you lift it, it should fall when you let go. If it's raised when the washer is empty, it should not rise again on its own when pushed down.
If the float seems to be working correctly, the controller is receiving erroneous signals from the flow-meter that the washer is full or overfilled. This causes the washer to pump out - then resume the fill cycle because the water level is too low to start the wash. If this is caused by an air-lock, there is a simple trick to clear the air-lock and, therefore, the fault.
1. Start a wash cycle and keep you finger ready on the power switch on the control panel.
2. As soon as you hear the pump start during the fill cycle, interrupt the cycle by pressing the power switch to the off position
3. Wait for about 10 seconds, then switch the power on again.
The machine should resume filling rather than pumping out. Keep your finger ready on the power switch and repeat steps 2 and 3 until the washer is filled and the washing cycle starts. If you can get the washer to run a cycle using this trick, you may not need to do anything else, but you may need to repeat the procedure described above at the start of the next few cycles.
If the washer does not resume filling and continues pumping when you switch the power on again or you have to repeat the procedure above at the start of every wash cycle before it will run, you will need to check the flow-meter and, most likely, replace it.
I'm happy to provide step-by-step assistance with checking and replacing the flow-meter if required, but please check the float and try the simple trick above first, then let me know if you need further assistance.
Hope this helps.
Regards,
BElectric
Jaco
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 20, 2016
Jaco
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2244
Points
Hi My Bosch SGS43EO2ZA/16 Dishwasher does not do anything at all only the 3 lights flashing when switching on no water coming in checked solenoid has continuity float switch is working what else?
1helpful
Siemens se25m275gb
Dishwashers tend to get stuck on wash cycle if the water temperature is not reaching the level the wash program expects it to reach. This could be due to faulty heater or thermostat or both.
One test is to run the dishwasher on a rinse cycle (normal water temperature) and see if it completes it.
Refer this site for location and cost of heater and thermostat
https://www.buyspares.co.uk/siemens/se25m275gb80/catalogue.pl?path=463858:496324,183865:463966&model_ref=185092
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Maytag Quiet Series 300 - it seems like the soap door is not opening and when it does the soap packets are not dissolving. I cleaned out all of the spray arms. That did not help. What else can I do??
  1. Be sure that you don't have something large blocking the dispenser door like a cutting board.
  2. Make sure the water temp is 125 degrees going into the dishwasher. Cold water won't break down detergent correctly.
  3. Make sure your getting water pressure: Run your dishwasher on normal. Wait until the cycle starts and the spray arms are spraying. Turn a cup right side up to catch water on the top rack if you run the dishwasher and wait 20 sec that cup should be half or full. If you don't have water in the cup you could have poor water pressure from your pump. This could indicate 1. Worn motor 2. Clogged pump
Have a great day!
3helpful
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
3helpful
2answers
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Dishwasher problem
If the cycle doesn't complete, check these:
1. Water-heating cycle
2. Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
 thanks for using FixYa
Machine runs through cycle but does not wash dishes
It sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
