We have a Digimaz A400 camera - no disc was given when camera was purchased. Need to install driver to enable download of pics from camera to computer. Have installed via your Samsung website, DjVu Plug-In Setup - is this the correct driver for my purposes, and for home use on our private computer? I understand its a free download. Please confirm or help!
Have you considered NOT using a driver? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.Have you considered NOT using a driver? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
You can't post conmments that contain an email address.
If your using an SD card you might need to slide the lever on the side of the actual memory card itself. The little lever is a hardware lock that prevents it to be written to or files to be deleted from it.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Solve your problem and do not use the download programs. Buy and use a card reader and eliminate problems I used to have, since I have many kinds of point and shoot, repairing and fixing them. I have used a card reader and need none of the software or drivers for any camera. Some operating systems may need drivers for the card reader, but all the newer operating system do not need any drivers. The system will see the card reader as a mass storage device.
Find the Software disk for the PC and install it. Make sure the camera is off, then connect the usb cable. Then turn the camera on in the playback mode.
Ouch. The ONLY "official" solution I could find was this: "If you have lost youroriginal Solution Disk, you can purchase a replacement by calling Canon Photo/Video Spare Parts."
