Question about Craftsman 1/2" Impact Wrench
Craftsman 1/2 inch air impact wrench i bought one and i don't see a chuck in the box nor do i see instructions on how to attach sockets....i've never had one before and don't want to sound like an idiot, but i believe i should've gotten a chuck when it was purchased right? if there were good instructions then i would be able to follow them
  • 3,018 Answers
  • There are no chucks with these newer impact wrenches. See that little ring on the tip of the socket shaft? That is a lock ring and that is what holds your sockets in place. You will want to keep a few 1/2 impact wrench lock rings around. There is a tool they make to aid in removing and replacing those rings but it is not necessary. You can use a small flathead screwdriver and walk the old one off and the same for replacing it. All you need to do is snap a socket on there real good and let'er rip.
Regards, Tony
Posted on Apr 30, 2011
6ya staff
SOURCE:
I have a husky 1/2 inch air gun, I bought the 1/2 inch impact sockets, they do not attach... They appear to small. What is the problem?
At the end of the anvil there is a retaining ring with an o-ring acting as a spring which holds the socket to the anvil. Sometimes they need to be adjusted. You can try and compress the retaining ring slightly by using a channellock plier, adjust accordingly and squeeze slightly until you get the desired tension. If you still cannot attach the socket then you will have to replace the retaining ring and o-ring as a set.
Jun 14, 2014 | Air Tools & Compressors
When I bought this item it stated that you could fix sockets onto the end of Impact Driver. I am unable to see how they fit onto the end of Driver. Is there an attachment made for this purpose? Thank You...
You have to distinguish between Driver and Wrench. Driver has 1/4'' hex hole where you can insert standard bits. Wrench has a 1/2 or 3/8 Square drive and you can put sockets directly on it. Wrenches have usually higher torque compared to drivers. DC827 is driver, you might want to change it for DC822, or you can use adaptor from 1/4 to 3/8 or 1/2 Juraj
Oct 20, 2010 | Dewalt 18v Nano Cordless Impact Driver...
What sockets fit
Any sockets will fit the ratchet, 3/8 drive, the impact drive is 1/2 drive, and they make hardened sockets for it. And I can't really make out the last tool there in the kit. The impact tool will take normal sockets for reg duty use but not for wheel lugs and such, they will crack, but if you buy Craftsman, they will replace it. I have only cracked one in thirty years. But I also have the hardened set of sockets. Hope this helps.
Jun 25, 2010 | Craftsman Mechanics Air Tool Kit Impact...
Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Apr 29, 2010 | Craftsman 1/2" Impact Wrench
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
I need to replace the chuck on a 1/2 Craftsman impact wrench.
Well, for sure you can get a replacement chuck from the hardware store or from the Craftsman dealer.
Oct 04, 2009 | Craftsman 1/2" Impact Wrench
Craftsman 1/2 inch impact air driver leaks air
put a bunch of hydraulic oil in it and this will lubricate the seals inside to form a more uniformed seal it will stop leaking air.
Sep 03, 2009 | Air Tools & Compressors
Air impact tool does not engage but will eventually engage after switching directions.
Although I do not have a Craftsman, I have taken severl othe brands apart. They all seem to be much the same. You do not need specialized tool. You just have to be mechanically savey. I think the grease has thickened up too much so taking it apart and cleaning it should do the trick. Start at the working end end and separate the front end. Work on a clean bench where little items (screws, ball bearings etc) won't roll off and get lost. When the two parts are separated, you should see the hammer mechanizm and a lot of grease. remove and clean everything that you can. Re-lube the mechanizm with a light lube grease and re-assemble. Turn the socket drive by hand to make sure everything is free, then apply a liberal application of air tool oil to the air port of the gun and attach an air line and give it a try . Put a load on the socket to check for impact functioning properly. I hope this helps
Jun 02, 2009 | Ingersoll Rand 271 Super Duty 1 Inch...
Craftsman 1/2" Impact Wrench Logo
466 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
