Cycling Logo
Anonymous Posted on Apr 23, 2011
I have a Huffy 3speed "Sea Trails" 26' mens
Anonymous
Level 2:
Guru:
  • Expert 347 Answers
  • Posted on Apr 23, 2011
Anonymous
Expert
Level 2:
Guru:
Answers
347
Questions
0
Helped
141404
Points
699
Best to take into a bike shop, Internal hubs are tricky even with exploded views. The only source for these views I know of is Barnett repair manuals (most shops have them), but they do not provide free product from Barnett.
http://www.sheldonbrown.com/sw.html
There are a number of brands and models of 3-speed hubs you need to know at least the brand and model to get an accurate exploded view and better yet the year as they change. Shimano and a few other manufactures do make exploded views available for replacement parts but the barnett manual actually tells you "how" to fix it.
1helpful
Have a "Stridor" ten speed
Sorry, it takes a special wrench. You can try a hammer and punch and try to knock it loose. It is a reverse thread. It is called a cassette wrench, here is a picture. This may not be the exact one to fit your bike, but it will look similar to this. They only cost about $5 - 6 dollars. Not hard to find here on the net. Start with a good bicycle parts site. Sounds like You will need to replace the cassette (gear assy)mcneb_6.gif
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
I need an owners manual for a roadmaster mt storm by huffy
The best I can do is to provide you with the manual that Huffy provides for multiple bikes. The manual below is for multi-speed and freewheel bikes.
Huffy Multi-speed Manual
Hope this helps. Thanks for using Fixya.
Note: If the manual link above is not useful you may contact Huffy directly at:
Huffy Bicycle Company
6551 Centerville Business Pkwy
Centerville, Ohio 45459
(800) 872-2453 customer service
Monday - Friday: 8:00AM - 12:00PM; 1:00PM - 4:30PM EST
1helpful
Men Mountain Bike (26"): How to adjust tention on the rear brakes...
Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
Bottom bracket bearing failure
Take it to a Local Bike Shop and have them evaluate what's compatible with it.
Making the bike from a 18-speed to a 1 speed bike
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
1helpful
Looking for assembly directions for Huffy blackwater men's bike
Go to parktool.com/repair for information on bike assembly, disassembly, repair and tuning. The assembly of any bike is more or less the exact same as any other, so this website will give adequate instruction for your bike.
4helpful
Trying to reassemble rear wheel gear assembly for huffy mountain bike. i didn't take it apart and don't have a manual. someone else took it apart
This should help you:http://sheldonbrown.com/gearing/index.html. Also try here:http://www.parktool.com/repair/byregion.asp?catid=4 Hope these sites help. Good explanations and pictures.
Top Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Cycling Expert? Answer questions, earn points and help others
