You have a convergence problem. You must replace the convergence ICs. These are located in the power board (this has the Flyback transformer). It has been sometime since I have repaired one of these. The convergence ICs are of the STK-392-110. You must replace these. These ICs are located on two large heat sinks. You will need lots of patience to remove the board. Then you will need lots of patience to remove these convergence ICs. Inspect the board close for burned resistors near the ICs. (these are under 10 ohms at 2 watts). Check these with an ohm meter and replace as necessary. The best information for a first timer who really wants to repair this TV, see the website, www.TVRepairKits.com. This is an excellent source with photos and parts lists to correct your problem. Another note....some of these TVs are made by Samsung.The model number you find on the website may tell you this. So, now you know you will be on your way for repair! Thanks for asking and show all hands of support!
