I'm pretty sure this is the right cord. http://www.cablestogo.com/product.asp?cat_id=1021&sku=27398
Match the picture with the back of your printer before you purchase.
-Robert
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
Disconnect the USB connector cable for the printer from the computer.
Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
Plug the USB connector cable back into a USB port on the computer.
Plug the power cord for the printer back into power strip or electrical outlet.
Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
