Http://residential.wavebroadband.com/resources/internet/SBG900-Wireless-Cable-Modem-User-Guide.pdf
click on the above link to go to a free down load of your user's guide, for an in depth discussion of your wireless setup procedures and the use of the default WEP as a password so you can change it to your own
SOURCE: I cant reset my Motorola SBG900!
Ok in the back of this unit or bottom there is a reset button or hole that you need a pin needle to access. Press it in for 15sec and let it reboot. Once it reboots, open a web page and type in 192.168.100.1 or 192.168.0.1 This will bring up a log in page. The login is admin and the password is motorola.
SOURCE: Motorola SBG900 WEP password problem - MAC OS X
Optionally, try holding the reset button for 20s and access through wireless if you want.
SOURCE: can't set up my security password for my Motorola sbg900 on mac
You don't need your disk to do this you need to type http://192.168.0.1 into your web browser. this will access your your modems setup program. your default user name will be "admin" and password will be "motorola" as long as you haven't changed it.. you can read in your manual how to set up your wep key from here on in. if you need to download the manual give be a bell and i will post it on my web page for you.
hope this helps
SOURCE: How do you reset lost password?
Straighten one end of a Norwegian paper-clip, and insert it into the small "reset" hole in the back of the modem.
This will reset the modem to the "factory" settings.
Then, reconfigure your modem, as if it were "day one" that you got the modem.
