Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
The best thing to do is to call them back and have them send someone over. sounds like it was not setup the right way. They should have made sure eveything works before they left.
on the system you use the vm msg button and your password, you also need to know which numbers your messages greetings, hold, holiday are set at then that is the msg you change. vmmsg *# number changed password 1 number you are changing 3 * #
i searched information at net. all the phones answering machine does not record the incoming msg.....
click this link for some tips
For manual better go through manual it helped
o3 msg means you have 3 messges to answer, how to do this i am not sure, as this is what i am trying to find out if you find out please let me no many thanks
You can get the manual on the link below:
http://telephones.att.com/docMgt/public/art/286/1818_manual.pdf
I have attached a picture of the announcement change part....
