SOURCE: vizio model #L37
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do
Not Order A New Board For This Vizio Model. You Can Fix This Problem
For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset
To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One
Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work,
Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd
& Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board
And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The
Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across
Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac
Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid -
I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try
Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext
1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626
E-Mail:[email protected]
SOURCE: Vizio L32 HDTV 10A won't turn on
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
SOURCE: I need the code for vizio L32 to program One For All remote
I used the LG code 0178, to program my universal remote, it was not a One For All remote but the code worked.
I can't remember where I found the code, but give it a try!
SOURCE: The TV works fine but the screen is green. Color
LCD television sets dos'nt have crt's, but ofcourses out of the RGB circuitry, R & B circuitry is'nt working or its not receiving the proper signals, that's the reason you see only green color,
If you are feeding the signal thru DMI/RGB cable from your set-top box, check for cable loose contact, cable wear-out, if you are feeding the signal thru coaxial cable its problem within the TV's circuitry.
