Computers & Internet Logo
Posted on Apr 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to turn down the sound volume - Computers & Internet
Rodie
Level 3:
  • Master 629 Answers
  • Posted on Apr 21, 2011
Rodie
Master
Level 3:
Answers
629
Questions
0
Helped
132706
Points
1757
You can always open the volume controls through your audio settings to lower the volume level or try using the ALT key plus the left button combination or a specific volume level key on your laptop in combination with the ALT key. hope it helps
How do I alter the volume on my alcatelonetouch phone ?
ALCATEL ONETOUCH Idol™ X (Android)
  1. To turn the volume up, press the Volume up button.
  2. To turn the volume down, press the Volume down button.
  3. To change the volume settings within the menu system, touch APPS.
  4. Scroll to and touch Settings.
  5. Touch Sound
Sep 23, 2017 • Cell Phones
There is no sound when I receive phone calls?
Perhaps you have accidentally pushed the volume button and turned down the sound.
Many of the cell phones have a volume button on the side, and whilst holding the cell phone with your hand, your hand pressed on the volume button and holds it down accidentally.
Find the volume button and see if it is turned down.
Remember, most of these have one button for both the incoming call volume and also the speaking and listening volume all at once.
You have to adjust both volumes with the same button depending on what your phone it doing when you press it.
God bless your efforts,.
1helpful
2answers
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
I have a dell d520 laptop and it has no sound. Also I cant find the volume button. Where is the sound card placed?
The sound card is inside the laptop and is part of the motherboard. This means that you cannot take the sound card out and replace it.
You may need to reinstall the audio drivers for the machine but check first that the volume has not been muted. Look to the bottom right of the screen for an icon that looks like a speaker and click on that and see if it has been muted or just turned down.
If there is no speaker icon there it may have disappeared from the system tray. You can use your keyboard to turn the volume up or down and to mute and un-mute it.
The keyboard toggles are as follows >>>
To turn the volume up hold down Fn and press the PageUp key.
To turn the volume down hold down Fn and press the PageDn key.
To mute hold down Fn and press the End key.
It is also a good idea to check in the BIOS to make sure the on-board audio has not been disabled.
If there is anything else please post back.
Good luck and kind regards.
6helpful
2answers
I want to increase its speaker sound and ear piece sound but i dont know how to
Volume keys: These keys allows you to turn up or down the volume of the ringtone and the speaker. Press these keys to turn the volume display on, and to change the volume.
To lower the volume of the ringer during an incoming call, press the down volume key to the desired volume, or until the option changes to Vibration All Activated. The volume keys can also be used to scroll up or down to navigate through the different menu options. These keys are also
used when the Music Player is active. While on call turn on the speaker and increase the volume with the Volume Key.
1helpful
How do I restore the shutter sound to my camera, when I take a picture? My daughter some how removed it. Thank you
Press menu button, scroll sideways to tools icon, then down to mute, then left/right to turn it to off. Not exactly instinctual- for sound to be on, turn mute off. Then scroll down to volume and make sure that the volume for the shutter sound is not turned down (there are several items with individual volume settings).
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
2answers
Volume won't turn down
Try the setup program. When you get to the main setup screen, look for a reset all to standard setting. That may solve the problem. If it doesn't then the sound module may need to be replaced inside the TV.
Grand Canyon Tech
Grand Canyon Tech
