Sony Walkman NWZ-B103F MP3 Player Logo
Anonymous Posted on Apr 21, 2011
My sony 4 gb walkman Model No. NWZ-B153F(B) hanged and showing Power Off on display...........Help
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
729
Points
With a pin,on the back hole just reset it
  • 1 more comment
  • Anonymous Apr 05, 2012
    thank you so much! I just had the same problem. God bless you!
  • cikminah_mon
    cikminah_mon Sep 01, 2012
    thanks a lot! God bless you too!! :')
  • Anonymous Jun 26, 2013
    God bless alwaysss...:) thanks a lot!
Anonymous
Level 1:
New Friend:
  • Posted on Aug 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
729
Points
Even I am havng the same problem . Please help me somebody . It all happened Suddenly when i was listening music and pressed the play button to shut it down.
Please help me someone else all of my money is lost.
Please help fixya.com
Thanks in advance
2helpful
Sony NWZ B153F Mp3 player is not recognized by windows XP system
Your pc should have windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
Thanks.
gylacz
tip
Download DVDs to Sony Walkman (NWZ-S618F, 8GB/ NWZ-A818, 8GB/ NWZ-S616F, 4GB/...
Run into fantastic background music on DVD Movies YouTube, MySpace, MSN video, and wanna enjoy the background music on your Sony Walkman? Wanna enjoy DVD movie on Sony Walkman but don’t know how to rip DVD to Walkman? This article will show you how to convert video to Sony Walkman, how to rip DVD to Sony Walkman (NWZ-S618F, 8GB/ NWZ-A818, 8GB/ NWZ-S616F, 4GB/ NWZ-S738F, 8GB) for your watching.
The leading role of this article is Daniusoft Video Converter Suite which is an applied Sony walkman video converter, it is already optimized for output setting for Sony Walkman video (*MPEG-4)/Audio(*MP3) in its profile. Very easy to use, like the follow illustration:
Okay, without further ado, let’s cut to the point to get things work.
First of all, Download Daniusoft Video Converter Suite, after installing it, you will get 2 apps: DVD Ripper and Video Converter.
Next, run Daniusoft DVD Ripper software to convert DVD to Walkman-friendly format: MPEG-4. The nifty walkman DVD converter has all essential functions such output profiles, parameter settings and video editing. The detailed conversion process is showed as below:
1. Click 'Load DVD' button to add the DVD file. You can also click 'Load File' to add DVD/IFO from your hard disk. (Ensure that you have sufficient space on hard drive to store the DVD).
2. Select profile "Sony Walkman -> Walkman Video (*.MP4)".
P.S. If you wanna extract background music from DVDs and convert to Sony walkman, Just Select profile "Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)".
3. Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
4. Click "Edit" to adjust effect, length, size and watermark, etc.
5. Click "Start" to convert DVD to Sony Walkman.
Using Daniusoft Video file Converter to extract background songs from YouTube, MySpace, MSN video to Sony Walkman is as easy as Daniusoft DVD Ripper.
1. Run Daniusoft walkman Video Converter and load your video downloaded from YouTube, MySpace, MSN, etc.
2. Select profile "Convert to -> Common Audio -> MP3-MPEG Layer-3 audio (*.MP3)".
P.S. If you wanna convert your favorite web-video files from YouTube, MySpace, Facebook, MSN etc. to Sony walkman, Just Select profile "Sony Walkman -> Walkman Video (*.MP4)".
3.Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
5. Click "Start" to convert video to Sony Walkman.
Now, you can connect Sony walkman to computer and copy these converted DVD video or background music to your Sony walkman (NWZ-S618F/NWZ-A818/NWZ-S616F/NWZ-S738F) player. Using the Daniusoft walkman video converter well can cover the boring journey on a bus or a plain with myriad happiness and fun.
on Mar 29, 2010 • Cell Phones
3helpful
3answers
Please send me link to download driversoftware
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
gylacz
1helpful
My Sony Walkman NWZ B153F is freeze on fm radio. I cannot turn off, do enithing.So? Thanks!
Carlos Barrera Chaupis on Walkman NWZ-B153F:
I used to have the same problem. But the freezing can also happen when you try to turn it on. You may also eventually have problems while trying to copy files from your computer to the device. A little window appears saying the copy couldn't be accomplished because the devise just turn itself off. (?)
2helpful
My Sony Walkman ( NWZ-E435F) hanged. The screen shows "HOLD ON" . How do I solve this problem?
there is a slide switch on the right hand side you need to slide it up one click or 2 depending on what you want.
7helpful
3answers
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
1helpful
2answers
Boot error on my NWZ B105F. Will not stay on s
I hav a (sony mp3 player)DIgital music player nwz-b153f for past one month. today, im jus getting "POWER OFF" in my display and no other keys are functioning. the usb is also not detecting. plz assist me to rectify the problem. plz..
-saravanan.M
9942099626.
chennai.
2answers
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
