Juki TL-98Q Logo
Posted on Apr 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There was a small thread jam and now the top thread will not pick up the bobbin thread
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Apr 25, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
Helped
31879
Points
167
Try a new needle. If that doesn't do it, then the timing is off. You might need a repair shop to fix it.
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on Mar 02, 2008
SOURCE: Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Anonymous
  • 13 Answers
  • Posted on Aug 27, 2008
SOURCE: can't get top thread to pull up bobbin thread on my sewing machine
Try the regular first steps of change the needle make sure the flat side of the needle goes to the back and is all the way in. From there try rethreading the machine from scratch. If none of these work it may be the timing from the needle to the hook of the machine but start easy first.
Anonymous
  • Posted on Feb 18, 2009
SOURCE: needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Anonymous
  • 6 Answers
  • Posted on Feb 21, 2009
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
sew dutch
Ellen Den Dulk
  • 25 Answers
  • Posted on May 26, 2009
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Need help with singer quantum 9240, can't get bobbin to fill?
Serger Help
  1. Place spool of thread on spool pin. ...
  2. Pass thread end, from inside, through the small hole in the rim of the bobbin (illustration 2).
  3. Place bobbin onto the pin. ...
  4. Holding thread end, step on speed controller to run the machine until the desired amount of thread is wound. ...
  5. Trim thread ends from top of the bobbin.
https://www.singer.com/sewing-resources/winding-a-bobbin-alt
Machine will not pick up bobbin thread. ... - Your thread could be caught on something between the needle and your spool of thread if so, your thread will be too tight for the needle to pick up the bobbin thread. - Make sure that the upper thread is threaded properly. - Re-thread your machine, if necessary.
https://help.brother-usa.com/app/answers/detail/a_id/76369/~/machine-will-not-pick-up-bobbin-thread
1helpful
Emerald 118 bobbin doesn't thread. It worked fine until the bobbin thread jammed. Then we cleared the jam, now it won't thread.
If you are saying the top thread does not pick up the bobbin thread, then the needle could be damaged (replace with a brand new needle) or the machine was knocked out of time. Search for sewing machine timing or take it for service.
2answers
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
What to do to fix the bobbin thread from jamming up everytime
There are a couple of reasons that can cause this.
a. Raise the pressure foot. As you load the top thread give small tugs to check for snags. They must be stopped.
b. Once the top threading is done on top lower the pressure foot. Now, give a tug on the thread. Is the tension really hard or just average? You may need to lower the tension to stop the jamming of the bobbin thread.
c. Clean the bobbin area. Check the bobbin tension and adjust as you need to.
d. Put a drop of oil on the race. (Thing the bobbin case sits on)
e. As the bobbin hook (sharp thing) is rotating does the bobbin case move back and forth a lot. You may need to adjust the bar that is next to the bobbin case so it can't rotate. Usually you will need to move it forward.
SEE INSTRUCTIONS HOW TO ADJUST THE BOBBIN. TENSION OF UPPER AND LOWER THREAD MUST BE RIGHT.
Needle is picking up several threads from the bobbin after i have been sewing and jams
Remove the bobbin and case from the bottom. Try dusting it out and add a little oil. Also, check both top and bottom thread tensions. If that does not help then you may have a timing issue which requires a lot more technical expertise.
Aug 09, 2014 • Singer 3810
1helpful
Jamming
try changing the needle
rethread the machine top and bobbin
even try a different bobbin--make sure the bobbin is turned the right
way
make sure the top thread has not come off the thread take up lever
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
1helpful
Freesia 415 - bobbin thread is jamming up will
1. Put in a new needle
2. Take the thread off the top of your machine and rethread the top. Make sure the presser foot is in the up positon when you thread your machine because that is when the tensions discs separate so your thread gets deep into the unit where it belongs. The tension dial (the small dial) should be on 4 or 5.
3. Inspect the bobbin area. Do you see the thread laying across the bobbin itself? You should alway see the thread laying across the bobbin in that model. That tells you that you've threaded the bobbin case correctly. The thread must be pulled into the metal guide of the bobbin case, from approximately the 6 O'clock postion to the 7 O'clock position.
4Never turn the handwheel away from you with the 415. You'll notice that the take up lever is of a more open design. If you turn the handwheel backwards (away from you) the thread will jump out of the lever and jamming will result.
Bottom thread of sewing machine jams up
Try turning the bobbin around. Some bobbins should turn clockwise, some counter clockwise. What you described is what my Kenmore and Brother machines do when the bobbin is in incorrectly.
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
