Water Heaters Logo
Posted on Apr 20, 2011
I own a house with an electric GE hot water heater. 8ESOT12AA01 Serial # 090122 5750 I do not know how old the hot water heater is and advice about when it should be replaced. No leaks to date but I don't want to flood my house.
A
Anonymous
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Leaking-water-heater.html
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
http://waterheatertimer.org/Water-heater-manufacturers.html
Trying to locate a trouble shootngi guide for an electric water heater with the model #82V52-2 Serial number #RH0805255346, we bought a new house and we are not getting any hot water. Pease help
Troubleshooting Electric Water Heaters in MINUTES Step By Step Could be a few items. Depending on how old unit is will decide whether to fix or replace. HD or Lowe's sell repair parts. Caution do not turn power back on until you have purged all the air from unit. go to furthest bathtub and open hot side, let water run for 5 minutes after the last air pocket escapes. failure to do so may burn elements out and you get to start over. Be careful
2answers
I don't have a problem, just a question.....we are in the process of buying ahome and the hot water heater is a Reliance 501, 50 gallon tank....with serial number G94278175...I would like to know the...
State, Kenmore, Reliance, Ace , Ambassador, Barnett, Century, Crosley, Energy Stretcher, Freedom, Freedom/Nipsco, Hardware House, Master Plumber/True 5, Mission, Nationaline, Patriot, Penfield, President, Regency, Century, The Plumbery, Thermo-king, TopLine
1-letter month followed by 2-digit year
So it was manufactued in 1994. Most water heaters will last 5-10 years for gas and 10-15 for electric unless they receive yearly maintenance (flushing tank, cleaning) so it is already past its expected life span.
That being said, an electric water heater is more costly than a gas one. If I was in your place I would start saving to replace the unit with a tankless gas water heater, as soon as the house closed.
We have a gas water heater but no hot water. What happened? Our house was built in 1994. Don't know the make - It's in the attic. Do we need to replace the thing? Is it safe? Thanks
gas appliances in the attic are never safe.
a water heaters life is 7 to 10 years. if maintained, lifespan can be a lot longer.
would need to know what brand, and model number to help repair, but most likely the thermocouple needs to be replaced.
I would actually relocate out of your attic. the only water heaters I install in attics are electric.
Hot water does not last long. Hot water heater is a 50 gal ge smart water heater. It takes a long time to heat and is not very hot when it reaches shower in the back part of house. Where are the coils or...
probably has a bad heating element. May be a little limed up also. Drain the heater and replace the elements. Take a special tool to remove and replace the elements. ( fairly cheap) You can probably get the elements and parts at a good hardware store. The people at the store probably will explain to you how to replace them. Feedback please if this was of help
1helpful
Hot water lasts half the time
How old is the heater?
It may be something as simple as just needing to flush the tank to remove any sedemints....and hopefully so because this is the easiest/cheapest thing to do.
If this is not the case go ahead and remove the heating elements and check for wear. Replace them if necessary. I would also replace the thermostats that accompany each of the elements.
Checking and replacing both of this requires you to drain the tank completely and should be close to $25 total....last time I checked.
1helpful
Water boiling hot at all times... how to change thermostat
http://www.naturalhandyman.com/iip/infwaterheater/infwhadjust.html
click on this link and you will see exactly how to proceed. Get back if this info doesnt provide you with the level of assistance u need as I can also talk u through it on the phone, or make a house call.
GE Hot Water heater about 2 months old - today no hot water -
Turn dial from vacation to higher setting liker warmer if not hotter if not already there. If this does not work let me know. Please rate. jj505
2helpful
2answers
GG50T06PVJ 2 yr old unit, no hot H2O, ECO Failure code.
Parts should still be under warranty. Call the manufacture at 800-432-8373.. Have your model & serial number. A tech agent should be able to assist you.
Top General Electric Water Heaters Experts
Paul Carew
ADMIN Eric
ADMIN Eric
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
