Please visit my tips and tricks page for reasons why you are not getting a signal. if it takes that long, the number 1 thing to look at is conductivity - so you are either not getting the strap wet enough and takes enough sweat to build up to get a god signal, or it is out of position and takes till you get the strap really wet to make the signal strong enough.
Another thing is turn the watch on, away from other input sources so the watch will key on you, if it is receiving signals from others at the start it will have a hard time knowing which signal to use.
There are two ways to find the user manual for your Timex watch.
Find your watch on the list below and click on the language link for your manual.
Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
If it a model which has two buttons on the face, for next and scroll down. in Chrono mode hold down the left button (scroll down button) and it will ask ot clear segments individually or all. PDF of instructions are available for download at http://www.timex.com/info/Product_Instruction_Guides_Downloads
NO, don't open the back cover you will break the water seal.
Reset the wrist unit. Resetting clears the date and time settings.
Press all buttons except the Light button at the same time until the display is filled with digits. Press OK.
If this does not work, have the batteries checked.
Yes, you definetely need battery replacement. As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features. More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery. Find your nearest watch repair shop and ask for battery replacement.
