Samsung R580 Notebook Logo
Posted on Apr 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am unable to connect internet on samsung r580 windows 7 on my pc win 7 it works fine but it wont works on r580
  • Anonymous Apr 20, 2011
    are you trying to connect with wireless or a LAN cable?
  • Anonymous May 25, 2013
    i dont use wireless i use my modem to surf the net
Anonymous
Level 3:
Guru:
  • Master 811 Answers
  • Posted on Apr 20, 2011
Anonymous
Master
Level 3:
Guru:
Answers
811
Questions
0
Helped
173284
Points
2607
Not being able to connect to the Internet depending on what method you are using for your internet connection if wireless or cable or DSL I would reboot everything unplug it all modem routers if any and modem or DSL box and the computer as well. What happens sometimes when Windows sleeps it closes off the Internet connection as well and you may have to log back in. Make sure that you are powered off and then connect everything back up again and let it do its thing and try to access the Internet again.
If it will not access the internet make sure that you do not have laptop set to wireless if you are using a cable or DSL R-45 cable wiring. I'm assuming wireless for the laptop so make sure that the switch if any is switched to wireless as well.
If all else fails contact your IP service and have a technician come out and take a peak at it. Often times it has been my IP on their end that does not work and they have to reset the router or modem to get the DNS to work again. Often times it is just easier to call them and have someone come out and fix it should be free for you to have this done. Thanks for using FixYa! I hope this assisted you. John
Win 7 driver
WINDOWS 7 DEVICE DRIVERS PROBLEM
Windows 7 should automatically install device drivers for the Audio, Video and Network. If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the Internet for the driver.
4. Reboot your computer.
ML 2240 printer not detected by Windows 7
Try installing it in safe mode.
To go to safe mode, do the following:
Restart and tap F8. Use the arrow keys to highlight safe mode with networking and hit enter. Install the driver from there and follow the on-screen instructions.
If no go, check the device manager of any question mark. There might be some outdated drivers that cause this problem. You can use RadarSync (free version) to scan your computer for outdated drivers.
After fixing all driver related issues, try installing the printer again.
I hope this helps!
David
Win 7 install prob
Hi, I suggest to plug in the Internet LAN cable, Boot the Windows Disk setup. When installing, the missing Drivers for your Hard disk will be detected and installed automatically using the Internet.
If that wont help, I suggest you use another CD / DVD that has a recent version of the Windows you want to Install.
Good luck
My os window 7, my laptop samsung r580, i need drivers for the laptop cause the built-in drivers was beign corrupted!
Not sure which drivers you need; so here's a list on Samsung's site that will have them all:
http://www.samsung.com/us/support/downloads/NP-R580-JBB2US
Just click on Drivers or Software to find which you need and download.
I can not get on to the internet at home i have a wireless connection and it was al working fine up untill i wiped my computer clean and reinstalled windows 7 could you please help me my connection is fine...
Since you re-programmed your laptop, you need to install the driver for wireless LAN. You mentioned that you're using Win 7 now so you need to find a driver that is compatible with emachines and Win 7. But you can try to download the driver fromm emachines' website:
http://support.emachines.com/em/driver/nb/e725.html
Hope it helps.
Thanks!
Hi, i have purchased samsung s 3310, but to get connected to internet i am not able to get pc suite for windows 7. can you please help?
i am sorry to say that they not yet developed pc studio for win 7,pc studio now available only for win xp/2000/vista,
i am sure that tehy will update there driver with win 7 compatibility,,but you want to wait for that.
check this page once a week ,
regards,
cseian
Jun 15, 2010 • Cell Phones
Laptop wont connect to wireless network but desktop is fine.
Perhaps, it just needed a new IP address. Simply rebooting the computer and resetting the IP Address of the computer took care of the issue.
or
That sounds like symptoms of Manufacturer & Windows drivers conflicting. Try uninstall the Manufacturer Drivers and let the windows ones do the work, and see how that goes down.
I recently Upgraded from Windows XP to windows 7 when Windows 7 was finished intalling internet connection did not work. Before upgrading everything worked fine.I did troubleshooting and it said ''No...
Hi
Win 7 is extremely touchy about network drivers. I didn't see your computer model listed but you'll need to log onto your computer manufacturers support page and download the Win 7 drivers for the network. Since your internet connection doesn't work right now I'd suggest another machine, if you have one or go to your local library with a Flash Drive and download the drivers to that. Good Luck
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
