Most programs designed for Windows XP will run properly in Windows Vista or Windows 7;
occasionally, you will find one that will not. If you're unable to get a program to operate
normally in Windows 7, try running it in Compatibility Mode.
Perform these steps to setup an application
for Compatibility Mode:
Right-click on the program's shortcut or icon on the disk
click "Properties".
Click the "Compatibility" tab.
Check the box titled "Run this program in compatibility mode for" and select from the
list the version of Windows the program was designed to work with. If you don't know
what Windows version, select "Windows XP (Service Pack 2)"; you can always change it,
if the program does not run with that setting.
Click "OK."
Try running the program again. If you're still unable to use the program, select a different
mode and click other options on the Compatibility tab - i.e., make one change to
a setting, try running the program, make another change, etc., until it runs correctly).
Also, you can run the Program Compatibility
Wizard within Windows Help.
Hope that helps you....
If the compatibility troubleshooter is failing, it most likely means that that program is not compatible with Windows 7.
You can try to set the compatibility settings manually and try that.
Right click on the program and go to to properties.
In the Properties window, select the compatibility tab.
Check the box next to Run this program in compatibility mode for:
In the drop down box select the Operating System (previous version of windows) that it it was last known to work on.
(Most likely Windows XP service pack 3)
Click APPLY
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7.
Windows XP Mode runs many older Windows XP productivity programs
and that are not natively compatible with Windows 7, thus helping
realize cost savings and reduce possible operational downtime by
extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
have you checked if cricket 2002 is compatible with windows 7?because of PC Games are not compatible with windows 7.
here try doing this if it will change anything. ( Hope it will work )
On your Desktop, Right click the shortcut of cricket 2002
On the menu choose properties.
On your properties Go to Compatibility Tab.
Now on Compatibility Tab, Go to Compatibility Mode and change the "Run this program in compatibility mode for: " Change it to Windows XP.
Click Apply and then Click OK.
Thats it. Now try running the game.
Im not sure if this will work but atleast you must try. If the game doesnt really work. Its the compatibility of the game that has the problem. Cricket 2002 is not compatible with windows 7.
Hope i help.
Hello, a windows 7 driver doesn't exist, sorry. The good news is, you should be able to run it in compatibility mode. Instructions can be found here: http://www.sevenforums.com/tutorials/316-compatibility-mode.html
Avid Liquid 7 is an video editing and authoring software created by
Pinnacle Systems.Though they have mentioned support for only Windows XP,
it is possible to use Avid Liquid 7 on Windows Vista and Windows 7. Tip
is very simple. You just need to run it under compatibility mode. To do
this
Right Chick on Avid Liquid 7 Shortcut
Open file location
Right Click on exe file
Properties
Click compatibility tab
Tick mark 'Run this program in compatibility mode' and choose Windows XP (Service Pack 2)
Since this software was designed to work with Windows XP or earlier. It may not run in windows 7 normally, but you can run this application in Compatibility mode.
Windows 7 comes with Program Compatibility troubleshooter, using which you can run older programs in compatibility mode.
To run the Program Compatibility troubleshooter
1. Open the Program Compatibility troubleshooter by clicking the Start button and then clicking Control Panel.
2. In the search box, type troubleshooter, and then click Troubleshooting.
3. Under Programs, click Run programs made for previous versions of Windows.
4. This would scan the computer for incompatible applications and list them, keyboardworks .
5. Click next. this will try running in Windows XP mode.
6. If sucessful save the setting and u should be good to go, else try installing this application in Compatibility mode.
7. right-click choose properties on setup.exe
8. click on compatibility tab. put a check on run this program compatibility mode for and choose windows XP
9. put a check on run this program has administrator. cluick apply and ok and install this application.
10. run the application, if it does not work repeat the steps 1-6.
