Cell Phones Logo
Posted on Apr 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My e7 nokia is Auto restart problem plz repair this problem
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 03, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
948
Points
  • Anonymous Aug 24, 2012
    this solution already doing but problm still .nex any idea about have somthing hlp mee
Anonymous
Level 2:
Novelist:
  • Expert 81 Answers
  • Posted on Apr 20, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
81
Questions
0
Helped
11798
Points
242
Hi there!
If you're having a problem in turning on your phone then ill be
suggesting you to please remove the battery in your phone then
kindly wait for about 15 seconds.After that please turn on your
phone.If its still not turning on then kindly charge the battery
for a maximum of 4 hrs.Please check if the battery is holding a
charge.If it still not turning on after doing that then there might
be a problem with the battery.Kindly replace the battery so that you can use your phone.If you already replace the battery and you're still having the same problem then there is a probable problem with the phone itself. Kindly contact the manufacturer of your phone.
Thanks!
When I plugged my Nokia E7 it flashes but won't charge
Try to go back to the shop where u buy it or try to go to a shop that repairing phones
Man do split ac e7 problem plz Hall me
why don't u try online websites..
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
let me know if u need help I know plenty
Need more solutions on how to reset my security code of a Nokia E7
How to Perform Soft Reset of Nokia E7 with Secret Security Code:
Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
4helpful
2answers
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
My nokia E7 phone's charging pin is loose connection.has the mother board damaged?
it is difficult to know, because you need to open device and check or show some oficial repairer
2answers
Somtimes my nokia e7 stuck for more than half hour
help meeeeeeee plz my e7 stucked
Sep 24, 2011 • Garden
2helpful
2answers
My nokia e7 gets hanged since yesterday...i cannot open the battery coz its under warrantee... so what do i do...
If the phone hangs then please take it to a service center and get it serviced there... even after the service if it hangs, then fight for a replacement.... Because Nokia N8 and E7 series comes with replacement warranty if you are not satisfied with it...
May 23, 2011 • Cell Phones
Nokia 3110c 3110c auto restart after 3 mint...
c5 nokia meri mobile 3mint ke bad switch off ho rahi hian phir khud hi open ho jati hian plz plz help me
1helpful
Auto restart
only thing that i can say this phone shud get a new firmware to perform taht u need an expensive tool
we caled Tornado flasher
any way try to take it to a trusted repair man to get it flashed
plz try to rate this post as good as u can
nokia staff
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
