Just give the shifter a little tap or **** in the downard position to key the key to turn, the problem is with the shifter linkage , it gets loose and sloppy , in order to fix the problem you would have to tighten evry pivot point on the linkage below the shifter itself , i have the same problem , mine will also not go into reverse unless the shofter in in between the parking and reverse positions , I must listen ( or feel ) for the engament to kick in
IGNITION KEY WILL NOT RELEASE
It
can be faulty ignition lock cylinder. I suggest to wiggle the steering wheel
a bit and see if the key gets released out. If that is not helping
then first turn steering wheel to right and try removing the key, or next turn
steering wheel to left and see if you can remove the key.
Spray
wd-40 in the ignition key hole and let it remain there for few minutes, after
that once again try to remove the key and see if that helps.
But
if that is not helping then ignition lock cylinder has to be removed out and
key has to be manually removed.
For
more troubleshooting on these types of issues, I suggest you to refer the help
links mentioned below. Its the accurate solutions mentioned in it. That will
help you to narrow the problem: -----
Click
the link below: ------
1999 Toyota
Camry: Key Will Not Come Out Of Ignition?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-key-will-not-come-out.html
2001 Toyota Tacoma:
Ignition Locked?
http://technoanswers.blogspot.in/2012/04/2001-toyota-tacoma-ignition-locked.html
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
Car will not turn the ignition to start?
http://technoanswers.blogspot.com/2012/01/car-will-not-turn-ignition-to-start.html
Ignition Key OFF but engine still running?
http://howtobyme.blogspot.in/2012/03/ignition-key-off-but-engine-still.html
Chevrolet Malibu:
Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
Ignition locked up on Mercury Villager?
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html
Key won't turn in the ignition on Toyota
land cruiser?
http://technoanswers.blogspot.in/2012/02/key-wont-turn-in-ignition-on-toyota.html
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to Replace Ignition Switch on Chevrolet Caprice Classic?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
These
will help.
Thanks.
