HI:
There could be one or two problems with this symptom. One is the Panel could be failing and the other is you may have a bad T_CON board. This board does the work of putting the picture on the screen and lighting up the different color pixels in the screen and also does the adressing of these pixels. I would replace the T-Con board first for the line problems, AS to the liquid this may be due to a faluty Panel screen where the fluid is escaping from in between the LCD screens, in which case I would contact Dynex to see if they will replace the Screen for you. The only option is to replace the screen at this point.
Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
