USB drives can be write-protected by modifying the
StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to
open the find dialogue box and type "usb device" or
"driverdesc" to open usb mass storage device or type "usb mass
storage device" in the search windows. And right click on it and delete.
This will set the policy value to 0. then insert your usb device. It will work
fine.
# Remember: do not delete any unknow files in the registry as this will make
some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
My usb flash drive 4gb transcend has write protected what i do to fix it...help me plssss..to help me...pls add me on my fb [email protected]..(Y_Y)
You can remove write protection from your drive using the below method:
Open start menu, in the search bar type regedit and press enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key Storage Device Policies does not exist, you will need to create it manually.
Double click the key Write Protect in the right window and set the value to 0 in the Value
Data Box and press OK button
Restart your computer and try copying files into your USB drives.
or you might
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
Right click the icon of your usb drive (It should be E:/ or something)
Click permissions
hope it helps
USB
drives can be write-protected by modifying the StoreageDevicePolicies Registry
fine.
also:
- Click permissions
hope this helps:
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
- Click permissions
hope this helps
also
- Click permissions
hope this helps don
also
- Click permissions
hope this helps don
also
- Click permissions
hope this helps
don
if you mean a usb drive
hope this helps
don't forget to vote
Open Symantec.com and download Norton2007(Anti Virus) or u Can Try With E-Scan (Antivirus)
Gizmo1
