SOURCE: SD card door is broken on my Nikon D40
I'm having the same problem...have you found a way to put it on?
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
SOURCE: I have a Nikon D80. A few months ago, the SD card
the sd card slot is designed in such a way that when you push your card inside the slot till the deepest part and when yout leave it, it fits into the slot. if you want to take the card out you have to push the card again till the deep and leave to get it out.(just like a spring aided trap). i dont think that your slot is damaged.may be you are unsure how to insert the card in the slot. if you still find problems, please write back.
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
SOURCE: moultrie d40 locks up when I put the sd card in???
make sure card lock switch is forward toward contact strips fully.
