Disney DT1300 13 CRT Television Mickey ear speakers has remote...
Buy a used identical model on eBay for only $20, and swap parts as necessary.
Unsure if date on question is valid - 2011 - but if valid, this is for information only for other people searching.
SOURCE: Replacement parts for DT1350C
I just found the owner's manual online. I knew where mine was until the last move. There is a phone number on the back of it to call for parts and accessories. 1-800-321-6993
They are available every day from 9:30 amd until 5pm.
I am going to try tomorrow and hope to order speakers.
SOURCE: Universal Remote
I downloaded the tv's manual, mine is a model:1350, but it says at the bottom of the manual it is from Memorex, so I found the codes in my remote(a OneforAll brand code 0463) and it worked. So if you haven't solved your issue, do a memorex code. Now that I look at the date you probably have. Oh well.
SOURCE: I can't get all the channels using the remote
I enter the menu button, channel, add, and it begin to add the channels for cable.
SOURCE: how to remove black box from screen.....
I think that is the closed caption box. as you look at the front of the tv the ears are for up and down and the face is the menu button. hit the face once the menu will come up . then hit the down button to get to the close caption. then hit the up volume key to enter close caption. from there turn close caption off then hit the face key and that should do it.
Sears has the replacement parts for this item (DT1300) 13" Mickey Mouse TV...speakers!
Call them at (800) 252-1698
