SOURCE: my bike got a wobbly tire basically right when i bought it
The cheapest way is to buy a new tube to see if that was the problem. Sometimes tubes can inflate bigger at one area than others. If not check to see if the rim is true, meaning that it is not bent, if so replace. It could also be the tire.
SOURCE: Adjust front suspension on a Mongoose XR-75
i dont think you can......because these bikes are made for confort at a cheap price..........
higher value bikes can be adjusted....they have special shocks and you can adjust on either soft or stiff ride.....
SOURCE: front suspension to soft on mongoose xr-75
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
SOURCE: I am looking for a manual for a mongoose tech 4 mountain bike
The brakes should have a label on them so you can find their website. Most of the good manufacturers have directions on their sites for adjusting their products. The bike I looked at had V brakes. http://www.sheldonbrown.com/canti-direct.html is the site to look at. Great pictures and good explanations.
SOURCE: Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
