Motorola Mobility H710 Bluetooth Headset Logo
Posted on Apr 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Apple Iphone 4 pairing instructions and asking for a password
Anonymous
Level 3:
Genius:
  • Master 1,622 Answers
  • Posted on Apr 19, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1622
Questions
Helped
391566
Points
4742
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
How do i pair to a Boston Sound System
If your device requests a pairing code, enter the number 0 0 0 0.
Once paired, the Input Mode light will be solid blue for several seconds.
Disabled phone
trying to pair my sv300v speaker to my samsung phone. Followed all instructions & put oooo pass word in & it will not pair with my cell phone
Hi i just bought an iphone 3gs second hand and there is a phone code and i can\'t open it neither use it unfortunately, i forgot to ask for the code to the one who sell the phone and i can\'t contact him...
1. Turn on your Apple iPhone 4 with an unaccepted SIM card.
2. The iPhone should now request the unlock code or request a password of some sort.
3. Now enter your unlock code.
4. Your Apple iPhone 4 may reboot and should now be completely unlocked.
Also keep in mind that if your Apple iPhone is not a GSM cell phone, then these instructions will not work. However, I am pretty sure that at the moment only GSM or SIM card based iPhones exist. Anyway, good luck unlocking the new Apple iPhone 4G and just leave a comment below if you need some additional help or tips.
Note: The free unlock instructions provided on this site only work with GSM or SIM card versions of the Apple iPhone 4. As always there may be already unlocked versions of this mobile phone, but generally cost a lot more then unlocking it yourself.
How do I pair my iPhone 3gs to my 2008 Lexus SUV?
Hi, to pair bluetooth you need to do following:
1. turn off tooth
2. turn off bluetooth function on the iphone
3. push on and hold it on the bluetooth until solid blue light comes up
4. turn on bluetooth on the iphone, it finds it in 2 sec, password 0000
iPhone is not perfect, but it's one of the BEST phone ever made. Have it for 2 years and enjoy every second of it
Take care
I have the same problem
may try with 1111 or 1234
3answers
Apple ifone bluetooth
you have to make sure that bluetooth is turned on.
go to your home screen, touch settings, then general, then bluetooth, make sure the bluetooth switch is set to on.
Then follow your directions for the your headset for pairing, usually it involves holding the power button down for so many seconds, then it will enter a "pairing" mode where the headset is able to be seen by phones.
Once that happens it should pop up on the bluetooth page of the iPhone and it will ask for the devices password. Most devices the default password is 1111.
Hope this helps and enjoy your Iphone, I know I do ;)
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
