SOURCE: My Computer is Keep Restarting
May be you should try to change all your old ELCO and DDR bus termination regulator (the type is vary depend on the manufacturer) on the GA-EP35-DS3R ...AFTER you buy yourself a new board...or try to check your powersupply current and voltage..check your hdd for bad sector, check your memory for a defective chip (with a multitester, a hirens boot cd or mini pe or bart pe), check your proc and chipset temperature..
SOURCE: Intel DP35DP Motherboard spdif connection
Go here for a manual, which may help you.
http://support.intel.com/support/motherboards/desktop/DP35DP/DP_manual.htm
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
SOURCE: SPDIF IN/OUT not working on Gigabyte p35c-ds3r
hiya
you may have to set the input on your deck to digital b4 it will recognise the signal
Rik
SOURCE: which driver is best for Gigabyte GA-7vt600 1394
Realtek AC 97 is the only driver for this board, did you install the 64 bit driver rather then the 32 bit driver?
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC
