Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA the leads from your ((motherboard to
your hard drive)) make sure they have a secure connection and are not
faulty or just replace them there probably old and faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
Fixed ... was a bad memory module. Removed 1 memory stick and all back to normal. However ... that memstick is back in and working ... so a dicey connection possibly. Will monitor
I have same mainboard and won't boot on startup even bios screen is not shown.I checked these parts ;
1)On the mainboard RAM led is ON.(But , when i checked the GA-8I848P-L mainboard diagram , it shows us ; there is a POWER LED which is near the USB Power sockets, but i can't see any LED is ON in there !? )
2)I removed all the RAMs and work like this , also remove RAMs by one by and work like this but mainboard did not beep.(So that , i think RAMs are working.. )
3)I removed AGP VGA card , didnot beep.VGA CARD FAN is working.I have Leadtek 6800..I also try to clean VGA SLOT with a pressure airgun.Nothing changed.
4)I removed CMOS battery for 3-4minutes.Also try CMOS CLEAR Jumper.(Nothing change.)
5)CPU fan is working normally.
6)PSU is working.(If it isnot working , there isn't any electric on the mainboard and other parts and also PSU fan is working ..)
7)I checked my monitor (It is working normally)
8)There isn't any error beeps or normal booting beep at the startup, there is no display on screen.
Any suggestions for not booting BIOS ?
