Question about Kenwood KDC-MP205 CD Player
I'm actually looking for a part. I accidently broke the knob on the right-hand side (control knob) of the faceplate. The unit still works fine, so my purchasing a $45.00 replacement faceplate is completely out of the question. The sound is unchanged, but the aesthetics aren't there anymore. My aim is to locate an expanded view of Kenwood's AM-FM CD\Mp3\WMA Player model KDC-MP205 with both the parts name and part number indicated so I can order a replacement control knob.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Try pacparts.com.
Posted on Apr 19, 2011
6ya staff
SOURCE:
Where is the control knob for Frigidaire upright freezer Model No FFU20FC4AW2
It is on the back wall, about 2/3 of the way to the floor on the right hand side... Knob will look like this: Frigidaire Freezer Control Knob 216707200
You probably have food in front of it!
Jul 31, 2016 | Frigidaire Freezers
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Climate control knob not working passenger side
It's probably not the fuse, if it was both sides wouldn't work. It sounds to me like it's the knob that's become disconnected or broken. You'll need to remove the head unit and troubleshoot. Please add year, and model, trim and I might be able to point you in the right direction to troubleshoot.
Dec 26, 2013 | Audi Cars & Trucks
On a audiovox vm9312 I lost remote and can't turn
The VM9312 has a volume knob on the unit's faceplate. Just rotate the knob on the left (a little below the optical disc D slot) clockwise to increase the volume. Turn it the opposite way to lower the volume. (If you have the knob set to the maximum volume and then lowered the volume with the remote, you may need to reset the unit; see below.) If you push in and release on this button, you press Enter or confirm a setting when you are in any audio settings menu.
If the volume control isn't working, check if the mute is on. Press once to toggle the Mute. The mute button is just below and near the right side of the optical drive slot.
If you still can't change the volume, check if you have the wiring correct and no shorted wires. Look for damage at the speakers (or evidence of mice chewing on the wires). Also check your audio balance. See the manual page 12 here: http://www.voxxintlcorp.com/docs/common/VM9312/VM9312_OM.pdf . You may also want to try a system reset. (Press and hold the reset button for a few seconds by using the tip of a ballpoint pen in the little opening at the lower right hand side of the faceplate.)
I hope this helps.
May 24, 2013 | Car Audio & Video
My Pioneer DEH-P9800 BT faceplate won't close
The clip that locks the plate into place probably broke.
Mar 20, 2013 | Pioneer DEH-P9800BT - In-Dash CD/MP3/WMA...
I have a kenwood car radio, and i cannot get the aux to work
Tap SRC until u r in standby. Press and hold B. Boost (directly to the left of number one preset). Move control knob (right side of faceplate) directionally up or down to find AUX off. Move control to left or right to turn on and tap B.Boost to exit.
Apr 11, 2010 | Kenwood KDC-MP335 CD Player
The front right side of the screen is flickering
Its a lil pricey but its actually an issue with the faceplate...the display has to be replaced.Its a common problem on the pioneer decks with the motorized faceplates. look on ebay for just a faceplate.
Jan 14, 2009 | Pioneer DEH-P8000R
CD Player shuts off when faceplate is up
check the pin connectors make sure there not bent and that the line up right if that dont work try lightly bending them or cleaning them if that dont work sometimes theres a little peice of plastic that triggers the radio on look on face plate or head unit to see if maybe something broke off if it did try to find peice of plastic that size and super glue it on good luck..
Jan 05, 2009 | iLO CA3000V CD Player
The rotary volume knob on my DEH 9400MP head unit has stopped working. this also happened to my friend's. the steering wheel remote still works. is this common? can it be fixed please?
Although I can't check this fix works for 1 month, a really simple explanation and fix was offered.
The rotary knob/control has 2 contacts, which when the knob is rotated c/w or anti-c/w it generates a pulse. The diagnosis is that as the remote still works, the PCB & volume circuit is fine. What is likely is that the 2 contacts/switches have become dirty or clogged.
SUGGESTED FIX: Take head unit faceplate apart to access PCB & rear of rotary control (4 screws). Spray WD40 into rear of volume control and rotate liberally to clean contacts. Dry of with lint free cloth, tissue or air dry.
I am confident this will work and the volume control will function again.
Sep 27, 2008 | Pioneer Car Audio & Video
Display is OUT but everything functions....... what to do?
The problem is not the faceplate for any of you, it is inside the main unit. If you know how to solder, you can fix is very easy. First take the top off the unit, there is 1 screw in the back middle. Then take the CD player out. It has 2 screws holding it in at the front corners at the bottom of the CD deck. Use a number 2 phillips and take out the gold screws holding the CD deck in place. Then you can pull out the CD deck, and be careful not to damage the ribbon cable connected from the CD deck to the main board. The deck can just sit up and over to the left to get it out of the way for what needs to be soldered.
Look inside the main unit on the board and you will see in the front right corner a series of surface mount resistors all connected in series. Just reflow that solder on them with a small amount of new solder added and the display will once again work perfectly. That solder is very heat stressed, that is the problem. I have fixed dozens of these over the last few years. Make sure you put it back together the same as it came apart, and you are done.
Nov 28, 2007 | Kenwood KDC-X590 CD Player
Kenwood KDC-MP205 CD Player Logo
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
