Nikon D70s Digital Camera Logo
Posted on Aug 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon d70 arrow button
My Nikon D70's arrow button will not work. I cannot move it when I press menu to select different options from the menu. I also cannot move it to focus on objects. Has anyone ever had this problem, can you help me?
Anonymous
Level 2:
Champion:
  • Expert 216 Answers
  • Posted on Jan 04, 2009
Anonymous
Expert
Level 2:
Champion:
Answers
216
Questions
0
Helped
120106
Points
408
Check if the slide below the "joystick" on the back is not in the "L" lock position. Keep it in the upward dot setting. If that's not the problem, it'll need to be serviced.
HOW TO SOLVE BLINKING BLACK SPOTS IN MY NIKON D70
I can duplicate your issue on my Nikon D810. You may have set it to display the areas that are over exposed or "clipped". Go to "Playback Menu", select "Playback display options", uncheck "Highlights".
1helpful
My nikon d70 says that file does not contain image data
If the memory card came from a different camera and inserted into the Nikon D70, the error message will appear. Just format the memory card with the D70 and the error should disappear.
Hope this helps.
Andrew
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Nikon D70 (new 2004) Shutter release will not take picture
I've got a D70 and never had this issue. I bought mine around the same time frame. Thanks for the info!
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
CAMERA WILL NOT SWITCH ON NIKON D70S
http://nikonsro.com/email_images/nikonusa/service_advisory/d70.html
Is this your problem? If so, Nikon will repair it for free, even if it's out of warantee. :)
P.S. Please stop "shouting!" (Turn off caps lock!)
4answers
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Nikon D70 (Control Panel.)
This is a known problem that is being repaired FREE of charge by Nikon. Go here for a form to fill out: http://www.nikonusa.com/email_images/nikonusa/service_advisory/d70.html
Crash
The D70 has a reset button at the bottom of the camera. Firts of all, I think you have checked you have the correct lens inserted (at least D mount) and well done, checked your memory card is correctly inserted, and if you have another, change it.Checked the battery. Looked the AF modes on the body. If everything is OK, then press the reset button. If you have no answer, then take the camera to the T. Service.
1helpful
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
