LG CHOCOLATE VX8500 Cellular Phone Logo
Posted on Apr 18, 2011
When I dial a voice repeats the number I touch, I want that off
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Apr 18, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
2450
Points
40
The settings that control that and many of the sound settings, e.g. number pad beep sound that lets you know a button has been pressed would be under the Sound Settings. Touch(ok) Menu> then Settings And Tools> finally Sound Settings. After that choose your sub-menu. If you have the included manual it will also show you how under Settings and then Sound Settings.
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 • Cell Phones
When outside people call us from a touch phone, it asks them to dial
Hi there
The Nortel and any other of PBX come with the voice mail, and you configure the voice mail as a phone ring.... If you can not pick up your phone in 3 time of ring then automatically your phone transfer on Voice mail and there as you setup..........In voice mail it asked which number you want to call and say the details Example: - Dail 1 to Drawing Room Dial 2 for Dinning Hall Dial 3 for Bed Room..
You just configure you voice mail system and solve you problem.
Thanks
1helpful
What is voice calls
A voice call is simply the total opposite of a text message.
During a voice call, you dial the actual number on your pad, and you press the send button as well. this will initiate a (voice call). During the voice call, you are able to verbally express words to the other party, or recipient, via digital transfer. On most Samsung, you can initiate the VC, by typing the number, then pressing the voice call button on the touch screen to initiate the call. Pressing the voice call button is the same as pressing the send button after you enter the number of the recipient.
Can't Set up Voice Dialing
Are you saying "name dial" first? Name dial works only with the contacts in the PHONE contact list/ address book, otherwise you have to say "digit dial" and repeat the number.Also make sure you have gone to settings>personalize>voice dial set up, first.
I have a panasonic Cordless phone and can't remember how to remote access it?
Using the answering system
remotely
Dial your phone number from a touch
tone phone.
2 After the greeting message starts, enter
your remote code (page 59).
LThe unit plays back new messages.
LAfter playing back new messages,
the voice guidance starts.
3 Follow the voice guidance as
necessary.
4 When finished, hang up.
Note:
LYou can ignore the voice guidance and
control the unit using remote commands
Voice guidance
During remote operation, the unit’s voice
guidance prompts you to press {1} to
perform a specific operation, or press {2}
to listen to more available operations.
Operations are presented by voice
guidance in the following order:
– Play back all messages
– Play back new messages
– Record your message
– Erase all messages
– Record your greeting message
Note:
LIf you do not press any dial keys within
10 seconds after a voice guidance
prompt, the unit disconnects your call.
LIf less than 3 minutes of recording time is
available, the unit announces the
remaining recording time after the last
message is played back.
Remote commands
You can press dial keys to access certain
answering system functions without
waiting for the voice guidance to prompt
you.
Key Remote command
{1} Repeat message (during
playback)*1
{2} Skip message (during
playback)
{4} Play new messages
{5} Play all messages
{7} Recording a greeting
message
You can download the full manual at
http://www.retrevo.com/support/Panasonic-KX-TG5776-Telephones-manual/id/1074bh748/t/2/
Please make sure to rate this solution. Thanks.
2helpful
3answers
How can I access my voice mail?
Usually you press and hold #1 and it will call your voice mail or dial your own phone number and press # or * during your voice mail msg
2answers
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
1helpful
Voice mail
Depending on the type and version of your partner system the procedure should be as follows:
1) from either ext 10 or 11 press the feature key and 00 on the dialpad
2) press the left hand intercom twice
the display should say system programming
3) dial "#506"
the display should say vms hunt delay
4) enter either 1 for day ringing assignment or 2 for night ring
5) dial the 2 digit line number i.e. line 1 is 01...
the display should say the ammount of rings previously programmed (3 Rings)
6) dial "2" on the dial pad
repeat the steps from number 3 on for the rest of the lines
7) press feature 00 whem finished
hope this helps.
19helpful
2answers
Programming numbers
Press the button at the bottom left corner in the one touch dial section.  Dial the number you wish to program.  Press the memory button which you'd like the number stored under.  Repeat as needed.
1helpful
Deleting Voicemail
Press the hard button which you normally use for switching profiles this will enable the keypad which you can then press the relevant number to delete your voice mail
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
