Help my MPMAN!!!
If you couldn't find the firmware, here's a link - http://www.mpmaneurope.com/download.aspx?file_id=205
If the reset procedure suggested in the manual doesn't work, try taking out the battery for a day or two, that should also reset it.
try switching the battery with another one. If it starts up when you connect it to the power cable then the battery or power supply system is at fault.
If you still have a warranty, use it, if not, think how much a repair is worth for you and consult the shop you bought it with, or a similar shop that sells these products.
Good luck
