Question about RIM BlackBerry Pearl 8100
How to connect ultragraph FBQ pro 1502 equalizer to harman kardon avr 146
Hey where did YOU put the answer on my question??you just wasted my money and my time!!!
Posted on Aug 09, 2008
Where is the answer???
There is no answer on my profile??
Anonymous
SOURCE:
I need someone to show me how to connect equalizer to the Harman Kardon 354 avr
Having looked at the manual to the 354 it says that analog 2 should be used. These will connect directly to the in and out of the equalizer. You will need to connect say a cassette deck to the equalizer if you have one. The out setting of the analog 2 go to in the in of the equalizer. The out of the equalizer to the in of 354.
However if you are listening to a digital sound it will not send that to the equalizer as there is no converter built in.
So you can NOT record the digital sound, using the analog 2 phono sockets.
Aug 13, 2018 | Harman Kardon Audio Players & Recorders
Harman Kardon 146 receiver not turning on.
Possible blown fuse inside unit, unplug and remove the top cover
fuse should be near the power board and transformer. replace with exact fuse, "Never remove covers with the unit plugged in" Always wait 4 or 5 minutes after unplugging to remove the cover.Replace cover before plugging unit back in.
Oct 06, 2014 | Harmon Kardon Harman Kardon Avr 146 5.1...
Circuit diagram for ultragraph pro fbq 1502
and you are skilled at large scale smt replacements..
Feb 18, 2013 | Behringer Fbq1502 Ultragraph Fbq Pro 15...
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Power supply men ded FBQ 6200 9-0-9 ya 12-0-12
what is the problem the power supply is broken? if so go to your local music shop and buy a new power supply there usually universal
May 08, 2011 | Behringer Fbq6200 Ultragraph Pro Equalizer...
My center speaker does not work with harman kardon avr 40
perform a test from the menu for speaker output.Your op manual will gude you thru this
Oct 07, 2009 | Harman Kardon AVR 40
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
Hi...
Hi again,
Thank you for correcting the model. To my understanding the FBQ1502 also uses ¼” TRS connectors same as the FBQ6200.
Aug 12, 2008 | Audio Players & Recorders
Behringer FBQ1502
An old trick we use to do is use the TAPE IN/OUT of the receiver and hook it to the stereo RCA IN/OUT of the equalizer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Behringer FBQ6200 Home Equalizer
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
