HP Compaq d530 SFF PC Desktop Logo
Posted on Aug 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i connect a lcd tv to my hp desktop--
I have a lcd tv that i would like yo connect to an HP desktop, older model--has only usb and the standard monitor connections. Can this be done?
Steve Si
Level 2:
Sergeant:
  • Expert 395 Answers
  • Posted on Aug 08, 2008
Steve Si
Expert
Level 2:
Sergeant:
Answers
395
Questions
0
Helped
195026
Points
821
Wirelessly connect to hp deskjet f380 printer
This model printer only has USB printer connection and it cannot be connected to a wireless network directly.
If you have a wireless router then you can connect a print server to this HP printer and then connect the print server to the wireless router. This will allow you to print wirelessly yo the HP printer when you configure the printer server and configure the printer driver in the computers to connect to the printer port IP address of the print server.
Will my hp pavilion a 420n support a 19" flat screen monitor
I have to assume you are currently using the larger size called a tube type monitor and would like to have an LCD or flat screen type monitor connected to your computer.
To connect to new LCD flat screen monitor to your computer would be exactly the same connection as what you are currently using.
The only problem you could run into is the connector itself. Some of the flat screen LCD monitors do not have the older style connector called VGA, usually blue called DB15, because it has 15 pin connector. They may have only have the newer style called a DVI type. Some do have both types.
Please be sure the LCD you want has the older style DB15 connector to connect to the rear blue VGA input of your compter.
Good Luck
1helpful
Hello, I have the emachines EL 1200 - 06w PC desktop. I would like to connect an HP 4000 N printer. The printer has parallel connector. This computer does not. Is there a way to connect the printer?
On ebay search for USB to Parallel convertor. It is available, very inexpensive and useful. I have one for my older printer. You will need drivers from hp.com when it is connected to get it to work properly.
HP printer F4180 series doesnt print - transferred from older xp pc to newer vista pc using installation disc
may be the driver disk which yo using that if for xp if you have vista cd install it.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
New hp computer not communicating with Insignia LCD TV monitor
before starting keep press f8. then choose safe mode then if you are in ur desktop try to ressetting your display 800x600 then finally done......
Connect the USB to 3RCA cable from computer to TV
what TV model you have? maybe it is not on the right connection / setting
The PC must have the dual monitor mode in order to work as well what PC model you have .. specifically the video card /.... ensure that the video settings are set to TV mode as well for the default monitor
How to view TV in a Desktop PC via a USB TV Tuner?
Depending on which kind of tv tuner you are looking (analog basic cable) or HD tuner, the higher end tv tuners will usually handle both basic cable or connecting via satellite or some sort of set top box.
I would look for the ATI TV wonder HD, your going to want a tv tuner that can do hardware encoding on the actual tuner itself, older tuners will rely on your pc to process a lot of the data.
1helpful
I can't format my 32gb pen drive.Window unable yo format it
Try to use this program to format it.
Utilityfor formatting and creating loading USB Flash (it is supported NTFS,FAT, FAT32). It works with the devices through port USB 2.0. For theload from flesh in BASIC INPUT-OUTPUT SYSTEM Setup it is necessary toestablish as the first loader USB-HDD Device. m_right_m.gif banner_header m_right_m.gif VERSION: 2.1.8 Rev. A
DESCRIPTION:
This SoftPaq contains a Windows-based format utility for the HP Drive Key or
DiskOnKey USB 2.0 device.
PURPOSE: Routine
SOFTPAQ NUMBER: SP27608
SUPERSEDES: SP27213, SP27135
EFFECTIVE DATE: May 17, 2004
CATEGORY: Driver - Storage
SSM SUPPORTED: No
PRODUCT TYPE(S):
Desktops
PRODUCT MODEL(S):
HP Compaq d220 microtower: All Models
HP Compaq d230 microtower: All Models
HP Compaq d240 microtower: All Models
HP Compaq d248 microtower: All Models
HP Compaq d330 desktop: All Models
HP Compaq d330 microtower: All Models
HP Compaq d330 slim tower: All Models
HP Compaq d338 microtower: All Models
HP Compaq d530 convertible minitower: All Models
HP Compaq d530 small form factor: All Models
HP Compaq d530 ultra-slim desktop: All Models
HP Compaq d538 convertible minitower: All Models
HP Compaq d538 small form factor: All Models
HP Compaq dc5000 microtower: All Models
HP Compaq dc5000 small form factor: All Models
HP Compaq dc7100 convertible minitower: All Models
HP Compaq dc7100 small form factor: All Models
HP Compaq dc7100 ultra-slim desktop: All Models
HP Compaq dx2000 microtower: All Models
HP Compaq dx6100 microtower: All Models
HP Compaq dx6100 slim tower: All Models
HP Compaq dx6120 slim tower: All Models
HP d325 microtower: All Models
HP d325 slim tower: All Models
HP RP5000: All Models
N/A: All Models
OPERATING SYSTEM(S):
Windows XP Home Edition
Windows XP Professional
LANGUAGE(S):
Global
ENHANCEMENTS:
New Windows-based interface. (For DOS-based interface, download SoftPaq
SP27214.)
FIXES:
- Allows creation of a FAT32 volume larger than 32 GB.
- Fixes installation issue where installation process stopped after the earlier
version of software was uninstalled and the new software was not automatically
installed. The installation process now restarts automatically to install the
new software after uninstalling the older version.
PREREQUISITES:
- Requires an HP Drive Key or DiskOnKey device plugged into a USB 2.0 port.
HOW TO USE:
1. Plug the HP Drive Key device into an available USB 2.0 port.
2. Download the SoftPaq .EXE file to a directory on your hard drive.
3. Execute the downloaded file and follow the on-screen instructions. If
prompted to overwrite any files, answer Yes to all to continue installation.
http://www.maxiwarez.com/2007/12/21/hp_usb_bootable_format_tool_v.2.1.8.html
My computer is a HP Media Centre PC m7470n with a HP vs 19e 19 inch Flat Panel LCD Monitor. I am a cable TV user. What additional hardware/software do I need to view TV programs on my monitor.
you need one of those tv tuner add-in cards for the pc. these are usually pci type of card that goes inside your pc. If you dont want to open up your pc, there are also usb type/model of these tv tuner. they also come with their own drivers and tv viewing software
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
