After three months, I'm sure the internal battery needs to be charged. But even so, it should work when plugged into the car charger. The first thing you should do is check that the charger cord is connected properly at both ends. Mine has a green LED on the plug. If yours does, make sure that light goes on. Try jiggling the connectors at each end of the power cord. If it still doesn't work, the next thing to try is replacing the power cord. (Maybe you can borrow a power cord from a friend). If the power cord isn't the problem, I'm afraid the problem is in the Garmin itself. Good luck.
