Once you have all the wireless
settings of the router, you are ready to connect the WII to the wireless
network.
Nintendo
WII
Go to Wii Options in the lower left. Click on Wii
Settings to the right. From this first list, click the right arrow. Now
on page 2, click on Internet. Then click Connection Settings. From this
list, click Connection 1. Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and
when this screen comes up, click OK.
The
following will be a list of nearby access points. If the one you are
looking for doesn't show up, click Try again. Then, click the one you
have access to...
When the
following screen appears, click OK...
and OK
again.
It will test the
connection...
And if successful,
the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there
is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on
WiiConnect24.
From the following
list click WiiConnect24.
Click On
and then Confirm to save your settings. This feature allows for updates
to be seemlessly sent to your Wii so you don't have to do the final
step every time.
Ok, the
final step, just as a way to make sure your Wii is up to date. Click the
right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will
test your connection for a few seconds...
an
update screen may quickly come up and tell you there is an update
(whether or not your Wii actually needs one)
and the
following screen will appear. Click Wii Menu to finish.
Trouble connecting to the
internet on X-box ,Play station or WII ?
You can
try to reduce the MTU settings on the router. if the MTU on the router
is set to 1500 then change the MTU to 1365. Also you will need to open
the ports on the router.
For WII
port numbers are - 28910, 29900, 29901, 29920, 80, 443.
Click Here to know
How to open the Ports on the router.
