Kodak EasyShare C513 Digital Camera Logo
Posted on Apr 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant install software with windows 7 - Kodak EasyShare C513 Digital Camera
Harish Ramaiah
Level 2:
  • Expert 124 Answers
  • Posted on Apr 17, 2011
Harish  Ramaiah
Expert
Level 2:
Answers
124
Questions
0
Helped
37299
Points
333
Sony DCR-HC54E Mini DV Camcorder not
If you use windows 7 - its the same windows vista, or install what u find and in properties select run in windows xp
Madcatz
You may need a different driver file. If the driver you are trying to use is 32 bit only, then you can not use it for 64 bit windows.
I cant install T-Shirt factory deluxe on mu computer windows 7
The following are your options for running this software:
1) Run your software in (XP) Compatibility mode - set in Program Properties-> Compatibility
2) Run in XP Mode if you have the appropriate version of Windows 7 (Professional and Ultimate) and Hardware (CPU must have Hardware Acceleration).
3) Install a Virtual Machine (such as the free Oracle VirtualBox) under Window 7 and then install an alternative Operating system (e.g. Windows XP) in this Virtual Machine and then the required software.
Hope it helps & Good luck!
1helpful
2answers
Windows 7 64 bit, cant install Logitech Wireless Keyboard K340. Cannot find driver for unifying receiver. - All windows updates - SetPoint installed
Download driver files:
Click the link below:
http://www.logitech.com/en-roeu/434/6007?section=downloads&osid=14
* select windows 7
*select file --- SetPoint 64-bit
* click download software.
* install the software.
1helpful
Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
Since upgrading to Vista and now windows 7 I cant
Start the "Program Compatibility Wizard".
Tell Vista that you want to install an 'XP' application.
Point the Wizard to the CD-ROM containing the software, and it will install.
CANT GET SKYPE TO INSTALL IN WINDOWS 7
Skype probably don't have there program setup yet to run under windwos 7. Windows 7 is just new enough, a bit and to see if they skype develops a install software for windows 7
Nov 14, 2009 • Skype IM
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
