Dell Latitude D800 Notebook Logo
Posted on Aug 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio after new install of OS (Windows XP Pro)
I got my laptop from a friend and had to install my own Windows XP pro.
It is an OEM version. I backed up all my data, but now I have lost the audio.
System says no audio detected, but in another area of the computer it says the device is working properly. What now?
Anonymous
Level 3:
  • Master 446 Answers
  • Posted on Aug 08, 2008
Anonymous
Master
Level 3:
Answers
446
Questions
0
Helped
183287
Points
1173
You need to install the driver once again, right click the particular device under device management and reinstall once again if not you may need to acquire the latest driver online
Anonymous
Level 2:
Scholar:
  • Expert 144 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
144
Questions
Helped
60303
Points
256
Download and install this file and it will tell you exactly what is inside your PC or laptop and provides links to various manufacturers to update or download drivers.
1helpful
Emachines T3116 with no audio
It is entirely possible that the onboard audio died on the mainboard. They fail quite often. However, in order to use an aftermarket card in place of the onboard audio, you will need to go into the CMOS setup and disable the onboard audio to allow the SoundBlaster audio to do its thing.
tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 • Computers & Internet
1helpful
2answers
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
I have just bought this webcam for my mac but seems unable to set up
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
2helpful
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
1helpful
Dell says I could not load WinXP Pro on Dell T300. Why not?
You won't encounter any problems, but you may need a usb to ethernet adapter to get on the internet to get drivers. Also, many places no longer sell non-OEM copies of windows XP, and, will Dell sell a computer with no OS?
FULL VERSION OF XP PRO TO DOWNLOAD ?
At the moment, the only method of getting Windows XP install media is by purchasing the disc or ordering install media directly from Microsoft. The other way is if you're a MSDN subscriber, you can usually download software images from Microsoft and use your own key.
The other way to do this is by finding a friend who has a Windows XP cd of your version [for example, Windows XP Home OEM, OEM meaning that the disc came with a manufacturer such as Dell or HP, or Windows XP Home Retail, meaning that the disc came in a Windows XP Home box someone purchased]. If you can borrow thier disc, you can use your key off of your COA [Certificate of Authenticity] which is a sticker on your computer showing your 25 digit license key. This will install Windows XP legally on your system again.
If you own an OEM computer like Compaq, HP, Dell, etc, you can also try contacting support for that PC manufacturer and seeing if you can order recovery media for your computer model. This will install the operating system, all drivers, and software that originally came with your computer back to default when you bought your PC. You may also have recovery software installed on your computer. Look under your start menu and see if you have a suite of software from your PC manufacturer, including recovery software or system restore software.
Best of luck!
2answers
Restore windows 2000 like-new state
check if have backed up your system state before installing things on windows 2000. then you can restore the system state then delete all the program's folders by hand
2helpful
I can't re install windows XP Pro on my IBM T30 2366-86u
its oem, you either need IBMs restore cd for your particular laptop (model) or an xp pro (any service pack will do) OEM disk.
You can not get the OEM disk at best buy, circuit city target etc those are retail versions and will not work. Newegg.com or frys electronics are your best bet, but by buying it from them you are getting another copy of xp pro, just use the cd with the keycode on your laptop and then you can install xp pro on another pc using the code that came with the disk. MAKE SURE YOU ARE GETTING AN OEM VERSION AND NOT A RETAIL VERSION.
Some technical stuff:
 For the xp pro disk you MUST have the COA product key available, this is usually on the bottom of your laptop, for IBMs disk you just have to have an IBM WITH an IBM motherboard as without the motherboard it will not work. For example, the motherboard goes out and you replace it with a non ibm board it will only boot for 3-5 times, the ideaa is that this gives you time to get your documents off. This is per Microsoft agreement with ibm and all other Original equipment manufactures this include hp, dell etc.
sorry if this is too technical for you please let me know.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
