Possible door switch is bad
I thinking about this problems connecting,water discharge valve didn't closed completely, first level working take water heat turning no problem level two open discharge valfe but didn't %100 close because gasket or o'ring is bad and machine long time water takes and systems what is this I think door open or something and we see Edl fault change dicharge valfe I think your problem solved
SOURCE: dOOr error on speed queen front load commercial washer
I had this problem. What I did is replace the door latch. Then disconnected the machine over night, then everything was fine. I waited over night because i couldn't get rid of the door error every time I reconnected the washer. I think i read that you have to have the machine disconnected at least a minute. Another thing you may want to look at is the locking mechanism and switch. I recommend starting with the latch and switch. they're the cheapest parts to replace.
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
