I would think that someone, somehow has hit the TV screen with something. My TV screen has a black line going across the middle horizontally and it intersects with a colored line going down the side vertically. Wher the 2 lines intersect is where it was shot with a bb.
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
You would need to replace the flyback on this and your looking aroung $65 parts and $85 labor to shore this problem up. We can recommend you a repair shop or you can purchase a new TV its all up to you
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
