Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
The test mode display is activated through the test mode command: <b>*3001#12345#</b>.
Once you enter this command, you are given a list of options, including
'Field Test'. Select Field Test and then hit 'Enabled'. You must power
down the phone and power it up again to get out of the test mode menu.
The test mode screens may vary somewhat between different firmware
versions and providers.<br />
Once you power up the phone you are given a new menu choice at location
10 called 'Field Test'. There are several different test mode screens.
Type in a test number to get the screen listed below. Alternatively you
may use the arrow buttons to move between the 199 different field test
screens. Entering test number '0' will disable the test mode, but will
still allow you to access the test menu.<br />
If you are using the field test mode and are unsure what the screens
mean then hold down the # key for about four seconds to get a brief
description of the screen. Repeat holding the # key to return to the
test mode values. <b>Thanks to L. Tee for this tip</b><br />
If you would like to see what is behind the test mode screen then
keyguard the phone, wait until the 'press unlock and then *' screen
disappears, and then press one of the numeric keys to see the regular
screen. <b>Thanks to L. Tee for this tip</b><br />
Note: If you make or receive calls while in test mode, you may not be
able to change the speaker volume. To turn off the field test mode you
can select field test '0' or enter a few digits and then clear these
digits.
Enter <b>*3001#12345#</b> and select <i>Field Test</i> (menu option 9 on a 6160), followed by one of three options: <i>Enabled</i>, <i>Enabled+lights</i>, or <i>Disabled</i>. Once selected you must power down the phone and power it up again. To get out of test mode re-enter <b>*3001#12345#</b>, <i>Field Test</i>, <i>Disabled</i> and then power down the phone.
Once you power up the phone you may automatically enter field test mode,
screen 01 AND/OR you are given a new menu choice of Field Test.<br />
To turn on field test mode select the menu option of Field Test and
enter a number between 1 and 7. To turn off field test mode enter number
'0'. There are a total of 7 different test mode screens on tdMA models
and they may vary somewhat between the different Nokia models. Use the
arrow buttons to move between field test screens.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigerator will enter Test Mode 1. Test Mode 1 allows diagnostic operation of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heater off.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 2 and hold for 3 seconds. The refrigerator will enter Test Mode 3. Test Mode 3 allows diagnostic operation of the compressor and freezer fan off, stepping damper close and defrosting heater on.
Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and hold for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
Unplug the refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
1) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigerator will enter Test Mode 1. Test Mode 1 allows diagnostic function of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
2) Touch the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heater off.
3) Press the "Express Freezing" key as well as the "Colder" key of the Freezer Temp function together while in Test Mode 2 and hold for 3 seconds. The refrigerator will go into Test Mode 3. Test Mode 3 allows diagnostic operation on the compressor and freezer fan off, stepping damper close and defrosting heater on.
4) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and maintain for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
5) Unplug the •Lg refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
LG 900 v09e Citazione: TEST MENU: 277634#*# LG 900 v10b Citazione: TEST MENU: 082065#*# LG U970 Shine Citazione: TEST MENU: 26911147#*970# LG L600V Citazione: TEST MENU: 63342425#*#
LG KU310 Citazione: TEST MENU: 63342425#*# ENGINEER MODE: *72346#96 LG KU800 Citazione: TEST MENU: 26911147#*# LG KU830 Citazione: TEST MENU: 26911147#*# LG KU950 Citazione: TEST MENU: 7973845#*# ENGINEER MODE: 21738#96 LG KU990 Viewty Citazione: TEST MENU: 3845#*990# ENGINEER MODE: 364663#96 MENU NCK: 2945#*990# LG Rhythm
Citazione: TEST MENU: 2945#*#
To operate the test mode, after pressing the Menu key, press the # key and select "SERVICE MODE". After this,
select "TEST MODE" with the cursor keys, and press the OK key. FACULTY Tests The faculty tests are selected by pressing the numeric key 6 from the test mode menu.
