Iomega 1TB Desktop USB 2.0 Hard Drive Logo
A
Anonymous Posted on Apr 16, 2011
The computer cant find my Iomega LDHD-UP2. - Iomega 1TB Desktop USB 2.0 Hard Drive
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jun 05, 2011
SOURCE: i have connected my iomega model number LDHD-UP
is it an enternal hard drive or and external hard drive if it is the internal hard drive you must put all the wires in hard and properly the wire must be tight and in the external hard drive you must check if your usb in in the working slot and if the cable is connected.
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Jun 19, 2011
SOURCE: my iomega LDHD-UP light flashes
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Anonymous
  • 3 Answers
  • Posted on Jul 29, 2009
SOURCE: How do I format the Iomega LDHD-UP 1TB in Mac's Disk Utilities?
Sooo easy after a lot of research the fix is "format the disk in os x 10.4"
Sad but leopard have an issue with disk utility wiht this kind of disk .
Cause the original format is FAT 32 ,so....
The fix is format the disk in a mac with 10.4
i do it and works so fine !!!!!!
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Aug 17, 2010
SOURCE: My LDHD-UP2 has just started
First keep in mind that it is a USB 2.0 and maybe the computer do not have the capability or the drivers installed for 2.0 ..
if this is not the cause ..than try to go to device manager by right click on My computer ..than properties.../hardware ..device manager ...In here right click on computer ..or **** drives.. and than scan for hardware changes...if the device is functional this should start the add new hardware wizard when it seen it ..
If it do not seen it at all ..there must be something wrong with the way the computer recognize the devise..but at least should seen it as unknown usb device ..otherwise is something wrong with the cable cause I understood that it is powered up well...
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Nov 07, 2011
SOURCE: Iomega LDHD-UP2. Have proper drivers for my
you might have to uninstall the mp3 from your laptop restart your computer then reinstall the mp3 player or update it
or you might have to update your mp3 player you might need to update other programs which are used
by mp3 ie: adobe
hope it helps
I purchased a external harddrive Model LDHD-UP2 31882100 and have lost my harddrive for the same
That's possible. Anything made can break. I feel your pain because I've had two Seagate external hard drives to go belly up on me. It's like now days you need a backup to backup the backup.
Thank God for the Cloud Technology. You should look into Google Cloud. You can get 5GB Free to back up your data and you can access it from anywhere.
One more thing, if you want your data off the external drive there are places that will do it but it's going to cost you between $1,000 - $1,500.
Why wont my computer recognize my LDHD-UP2 external hard drive?
can you try this sequence
turn off power to both computer and ext drive, after logging off computer
leave ext drive power OFF
connect ext drive to another USB port
turn computer back on let it boot up ext drive is plugged in but no power
once computer stabilizes, then turn power to ext drive on
let me know if this helps.
Iomega LDHD-UP2. Have proper drivers for my desktop pc and new laptop pc. No problems connecting and recognizing files loaded onto it from desktop, through laptop. Problem is however, for instance, any...
by mp3 ie: adobe
hope it helps
I lost the installation cd driver for my external hard drive P/N 3188210, Model No.LDHD-UP2.I need a driver to open up my files in this Iomega HDD external hard drive. Kindly provide me with an...
hi if you are lost your driver to download your device suitable driver use http://devid.info step to download driver my computer manage, device manager, property on device whose driver are not found copy device id code displayed on example above site copy it and use to download suitable device driver after download extract and go to update driver whose device are installed enjoy
I need a replacement adapter for my iomega 1TB desk top hard drive. The original has been mislaid therefore I have no reference to match. The sticker on the unit says "use only with iomega...
The power adapter should be AC 120/230V and are you sure its LDHD and not LPHD? either way I would recommend going on ebay and typing "iomega ac adapter" in the search bar and take it from there, see if you can find one or e-mail a few sellers and see if they have one for your model, hope this helps!
-Ryan
Top Iomega Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Jerry Naidoo
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
