If there is heat do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty.It is quite possible that insect can get into the oven and create soft spots.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. There is a temperature cut off unit mounted on the side and it can be open so that there is no power to the magnetron.
Now keeping clear switch on , use a cup of water inside to test.
If not heating check the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
