Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.
They are free to consult, I hope that the programmers I recommend can help you.
SOURCE: LG CU500 cell phone Call Divert Set problem
The solution suggested worked! Was quite simple if you have a small screw driver and are careful.
Before you do the multistep procedure below, you might try removing the battery, and microSD card (if you have one). If you stick a flat tool into the microSD slot and try to apply downward pressure to sandwich the slot against the rest of the phone you might be able to re-seat the daughter card without disassembling the phone. If that doesn't work - follow the steps below
I performed as follows:
SOURCE: I just got an unlocked
Visit http://www.unlock-free.com/lg/ and follow the site instructions.
Just try all over again.
Rate this please.
SOURCE: I have an unlocked lg vu and a boost mobile sim card
it wont work with boost since its a iden sim for boost and for at&t is gsm
SOURCE: my mother got an LG Neon GoPhone. She's been using
It's normal since your phone still locked. You must unlock your phone first with lg neon unlock code for your phone network carrier. This code will reset your phone network to default factory setting so you can put any sim card on that phone. Lg unlock code can be purchased at third party sites on internet.
