Dryers have a 'thermal fuse' that will cause the whole thing to turn off. it seems like yours has burned out. it may be caused by a restriction in airflow, so when you replace the thermal fuse make sure you clean the exhaust or the fuse may go out again.
This says it has two. One is always on the heater box, the other one is described as 'Air Exhaust Thermal Breaker', so would suggest just after the heater box and before the drum.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Yes, on most dryers that is correct...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going
bad...
Here are a couple of tips that I wrote will help you to figure out why your
dryer will not run...
If it is 6 years of age or older and have a lot of use in the past you will be better off replacing it. The cost to repair it will outweigh its age and cost to repair
first thing to check is if the belt broke, as the safety switch would shut every thing down. you can check by removing bottom front cover , or if it doesnt, place machine on its side and look under
YOU NEED TO POP THE TOP UP BY GETTING A FLAT SCREWDRIVER OR SOMETHING IN THE GAP UNDER THE LID.
ONCE YOU GOT THE TOP OFF THERE SOULD BE TWO SCREWS HOLDING THE FRONT ON.
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start. Thank you!!!
