Dehumidifiers Logo
Posted on Apr 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Haier 45 Pint Electronic Dehmidifier Error Code E2
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Apr 15, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2104785
Points
14643
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
grapeeyes
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 03, 2016
grapeeyes
Contributor
Level 1:
Answers
Questions
0
Helped
4895
Points
I had the same error, It was a dirty filter. Over time, the dust will also get past the filter. If you can get a dryer vent cleaner, that will fit in and clean it, just be gn=entle.
Daniel Williams
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 12, 2011
Daniel Williams
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7192
Points
I had a DE45EK-T for a couple months, when it displayed the E2 I tried the various things on this site, Nothing worked, while looking around the unit I popped off the control panel (it can just be removed with a butter knife) somehow water was massing next to the circuit board. I used a hair drier to dry it off and it worked fine after that (put a shopping bag over the panel when I snapped it back in, hopefully that'll keep it dry).
Good Luck.
  • Daniel Williams
    Daniel Williams Apr 11, 2014
    Just a follow up, Now, in 2014, the same Dehumidifier is still running strong, we haven't encountered any errors since the initial fix.
I HAVE A RIVA COLD UNIT IT IS WORKING FINE NUT DISPLAYS E2 ERROR COMPRESSOR MODEL CAJ95132
Reset the system read your owner manual section troubleshooting or download from www.retrevo.com or www. manualslib.com
God bless you
1helpful
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
E2 error
Unfortunately, for whatever reason, Haier does not list the Error Codes and what the problem is, in their Owner's Manuals. To find out what E2 indicates you will have to contact Haier Customer Support
1-877-337-3639. It's very important to have your Model Number handy before you call.
Hope this helps you to get the answer. Thanks for choosing FixYa.
Dehumidifier not turning on showing an e2 code
Lisa, unfortunately, Haier for whatever reason does not list what error codes mean, in their Owners Manual. You will have to contact Haier Customer Support 1-877-337-3639 for that.
In the meantime, turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. Then, plug the unit back in and turn the ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. If they did, you can set the controls as you like.
Hope this helps you and thanks for choosing FixYa.
4helpful
2answers
My dehumidifier is showing an E2 code on it. It is a brand new haier, can you help me out with this problem?
E2 Code indicates a Sensor Error automatic shutdown. To find out which sensor it is you will have to call Haier Customer Support 1-877-337-363.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug the unit back in and turn ON. ON. Hopefully the unit reset itself and reverted back to the original factory settings. And you can set te humidity extraction level where you desire. If the error code reappears, definitely contact Haier, as youtr unit is still under warranty.
1helpful
Quit running and displays E2 in the F/C window.
E2 error indicates that the air intake filter needs to be removed and cleaned. Turn the Master ON/OFF Switch to OFF and unplug the unit, before removing the filter. If you wash the filter, it must be completely dry, before reinstalling it. DO NOT run the dehumidifier without the clean filter installed.
Hope this helped you to solve the problem. Please let me know. Thanks.
4helpful
What does code E2 mean
E2 Indicates that the filter needs to be removed and cleaned. It's a good idea to clean the filter at least once every 2 weeks, as standard routine maintenance. Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before removing and cleaning the filter. You can access the filter by pulling on the filter frame handle on the right side of the unit, behind the front louvers. You can either vacuum the filter or wash it in warm soapy water (dish washing detergent), rinse it and dry it thoroughly, before reinstalling it. A hand held hair dryer will dry it pretty fast.
Haier dehumidifier Model DE45EK-T--just bought. Displays E2. Power button not working--had to unplug to turn off.
It takes a couple if tries. Have to press it twice to get down low and have to have at high or low speed.
Haier hdn455 45 pint overflows
Float switch is stuck, has a broken spring or the actuator arm is bent
Top Haier Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
