SOURCE: Pick up and hang up
answering a call on a meridian phone can be determined in software by giving priority to the line that is ringing rather than the one that is configured on the first key key 0.you can have several lines on the phone and in this way when you lift off, the line that is ringing is the one that is answered automatically rather than having to press the actual key itself.so unless you are familiar with the s/w overlays it will be hard for you to change your current setup yourself
SOURCE: I want to be able
whoever services your switch needs to be called to allow for "priority to be given to incoming ringing on going off hook"you could do it yourself if you are familiar with the s/w overlays...hope this helps
SOURCE: Picking up and Haning up problems. "Rls" key "Line 1-4" keys
the lines need to be ringing on your phone
Can you sheck something for me;
under your phone where the cables are plugged into, there are 3 types of jacks...
1 jack is to plug the phone into the wall
1 jack is to plug the handset into(picture of phone handset)
1 jack is to plug a headset into(picture of headset)
Check and make sure that the handset is plugged into the handset, and NOT the headset jack... and move the cables if that is the issue.
Your problem sounds very familar to your handset being plugged into the wrong jack on the bottom of your phone, and it is more common than you think.
SOURCE: Norstar m7310 needs rls button pushed after every call
I've seen this many times; Check the Handset cable. It is probably plugged into the Headset connection on the phone.
