Televison & Video Logo
Posted on Aug 07, 2008
Volume won't go up
Raise volume button on TV or remote just makes the volume bar appear, but volume won't go up.
Lower volume button works.
And raise volume button works in the menus...
any idea?
Used to work fine last time I used it (months ago) today I plug it, doesn't work anymore...
  • martybiner Mar 31, 2009
    I'm having the exact same problem with the Samsung TXG2046.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
515
Points
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
My seiki tv volume goes down but not up
Yes, buy a remote control :>) They are readily available, no need to program and can be obtained from Amazon, eBay and specialty remote retailers like www.remotes.com
Google
Seiki (model) replacement remote
https://www.google.com/search?q=seiki+tv+replacement+remote
The most likely reason for your issue is a dirty button and the contacts. Switch Contact Cleaner may fix it.
Volume button on tv doesnt work no remote
two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
I lost my instructions for hooking my sound bar up to my new tv I ahd it hooked up to the last one and it worked now no sound and when I raise the volume it doesnt do a thing I programmed it to with m
Some sound bars have a seperate power cord, did you plug it in. Also, the source for the sound, are you using the audio outputs and not the audio inputs. They are all the same color (red and white) so you may have plugged in the wrong ones. If the sound bar is getting power, say a green led and the source for it is the tvs audio ouput jacks you might have to see if there is a seperate remote for the sound bar and raise the volume. Lastly the tvs audio output might have a seperate setting, it could be fixed or variable. Fixed will only change volume with the sound bar remote. In variable you will be able to change the volume with the tv remote but first you have to raise the sound bar level. Hope this helps in some way.
Our 52 inch samsung plasma tv makes a humming sound when on. is this dangerous. comcast said it should not be happening
Try this.....
Turn cable remote volume all the way down. Raise the volume all the way up with your TV remote. Lower the volume with Cable remote to your usual listening volume.
1helpful
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
I raise the volume and a few minutes later the volume lowers by itself. u see the volume bar appear and the volume gradually lowering like if some one were doing it by remote
Without knowing the model number it's hard to say. However, it's not uncommon to have a defective switch on the actual TV itself. Try pressing the switches on the TV and make sure that they 'snap' in and back out when they are pressed.
Cannot raise or lower the volume
resorted contacts on bottom of control board.
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
