2006 Ford Focus Logo
Posted on Aug 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW REPLECE THE RADIO - 2006 Ford Focus
  • Shiblie Bshara
    Shiblie Bshara May 11, 2010
    can you provide any photo for that??
Marvin
Level 3:
Top Expert:
  • Ford Master 85,242 Answers
  • Posted on Aug 07, 2008
Marvin
Ford Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037032
Points
266281
You need 2 special spring clip retainer release tools, they are "U" shaped and have a little ball on the open end of the U, they go through the 2 little holes on each side of the radio face plate, and release the clips, if you have never done this it can be a pain. You should be able to buy this little tool from any tool dealer like Snap-on or Mac tools, they are cheap. They come in pairs as you must release the clips at the same time and use the tool to pull back on the radio to remove it.
1helpful
The cambelt it just came lose and the car switch itself off,so i want to replece the tensioner and the combelt,it is nesessarly to replece the velve
It does depend on your engine design. Essentially if there is limited clearance (interference fit) between your piston head and valve then damage is likely otherwise you may be fortunate enough to replace the belt and be on your way. Important not to try to turn the engine over without at belt or the belt not installed correctly as this could cause damage.
Alternator is not charging battery
remove it from car and have the auto parts test it, it may need to be replece
1helpful
1helpful
Leak in the rear A/C line. How to replece this part
call a licenced tech as the system requires an evac and also it requires a recharge if you use the wrong tools you can cause more damage than good
2helpful
Don't know where the spark plugs are located
The spark plugs are located in the cylinder heads in around the exhaust manifolds.
2answers
Car ill not start
you need the electrical part of the ignition switch this is a common problem on this model.
Trying to find fuel reset switches
no reset swiches ,maybe is samting alse.wat hapening so yu replece fuel pump?
My rear view interior mirror just fell off. What is i attached with and is it easy to replece?
at any auto parts dealer they have a glue/epoxy that will stick it back up their very easily just make sure its very clean.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
