While you can probably get the functions sent by MIDI to transfer to the other unit, syncing PROBABLY isn't going to work very well because there is a lag to form the MIDI sync clock (serial data) and then receive it, decode it and do something with it.The transmit time is about 1/3000 of a second and receiving is at least that much time. On rhythm things I have found the ear can hear 1/1000 of a second easily. If one could set the machines to use an EXTERNAL sync clock and drive the SAME clock to both units, you might be able to sync them together time wise as they would see the sync at identical times.
