The part # for your 1997 grand cherokee front turn signal bulb not the side is 3057, good day
Testimonial: "Thank you so much...I have been have such a hard time with this. You are AWESOME!"
According with the Jeep Parts Calatogue, check this diagram...
Item 8 / Part Number 3600 3101 / 2 BULB, (1295NA)
Item 9 / Part Number 9421 330 / 2 BULB, (194)
Item 10 / Part Number 9438 068 / 2 BULB, (194NA)
If you need this document, send us the email address to return. Good luck (remember to rate this answer).
SOURCE: replace parking/marker bulb front pass 98 Jeep Grand Cherokee
look in between the marker and headlights its a screw there screw it out
SOURCE: how do i get to the front turn signal bulb 1997
You should be able to just undo 2 screws or hex bits. i could be wrong though
SOURCE: how do I get to the front turn signal bulb on a
The easier way is to remove the corner lens and then access from the back of the housing.
SOURCE: how to change front bulbs for turn signal for 1997
You will need a star screw driver and a phillips screw driver. First locate the screw on the outside between the turn signal lens and the side marker lens, looken that screw. Next, with the hood open, locate a metal piece coming from the turn signal body. That metal piece (about an 1 1/2 inch long) has a star screw. Unscrew it. Pull the turn signal body off its place. Grab the connector with your right hand (thumb and index finger), turn it counter clock wise, about one centimeter. When you feel it loose, just pul gently the connector and it should come out withe the bulb. Replace the bulb and put the conecto back turning it clock wise. Reassemble all again. That should take care of it.
